Contrary to previous comments, I don't agree with some of the Pb free bashing. I agree than 10 years ago, Pb free was much harder to use than lead solder but things have changed. I did my first SMD soldering few weeks ago (after 10 years without soldering) with Pb free solder and it went relatively easy, up to 0603 and SSOP (if I forget 2 pad lift
But I was in a better condition of success than you :
- I used rosin flux (and it really help a lot, especially for ICs)
- I have a quality solder (with Ag), much easier to use than the Pb free I had 10 years ago
- I have a temperature controlled iron
From comments I had seen in this forum, this trio seem to be the condition to Pb free quality soldering.
However it ask for a certain amount of money (Ag is not cheap). If you can't get these, it's probably better to get lead solder... But more important, use flux. It really helped me a lot.
A temperature controlled iron is probably a good investment too. As SMD have a lower thermal mass, they can burn more easily.
There is also the fact that the PCBs I used had a solder mask which can help. For my first SMD soldering, I used a 1,2 mm chisel tip for components and a 2,2 mm for drag soldering ICs. If you get pins shorted, just apply more flux and drag the solder to the outside, so easy with flux.
