Hi! Thank you very much for your answers
So
Very comprehensive images. Nicely done. When you say the laptop starts and stops quickly, what you do mean exactly?
Thank you my friend
I meant that my laptop starts a few seconds and shuttdown quickly, the CPU fan also stops. It happens only when I plugged-in and unplugged the power supply adapter but if I try to start the laptop directly through the button nothing happens.
I would start at the battery pack first as the most plausible problem.
Many times when charging or power issues pop up for lap tops it turns out to be the battery pack. These packs have safety features built in that prevent charging when they fall outside of specific parameters. Even if one battery is out of specification yet the others are fine . This can also prevent the lap top from running off the AC/DC power supply.
I removed the battery, same problem my laptop does not work :/
Is the big connector with two red, two black the power jack connector?
Where's the battery? Have you checked if there is any voltage on it.
Have you tried with no battery attached?
Do you know whether this laptop works with no battery?
I had a problem with an Android tablet that was dead, dead, dead even plugged in.
The battery was showing zero volts.
I jumpered in a 1K to the battery and that was enough to get the charger logic to boot.,
1 - This cable give the 19v from the power supply adpater to the motherboard, I tested and I have 19 volts on the two red wires
2 - The battery is charging but the laptop is not power on with the battery
3 - Yes I tried, same problem, when I plugged-in the power supply adapter, the laptop run a few seconds (I can hear the CPU fan also) but it stop runing quickly.
4 - I tried without battery but is not working
Whats the model of the laptop?
Acer extensa 7620z 17 inch model
