Author Topic: My purchase list for my new lab -- budget $1000+, thoughts?  (Read 41158 times)
Offline rstofer
Re: My purchase list for my new lab -- budget $1000+, thoughts?
« Reply #200 on: August 06, 2018, 11:14:49 pm »
Might be a dumb question but if I am just sitting at my desk, hardwood floors, fiddling around with components on a table, how do I know if I am grounded or not? Do I need to wear a wrist-wrap connected to something else, e.g. the metal rack next to me? If the rack is just sitting on wood is it even considered grounded? Or do I have to touch something metal that's somehow connected to some other metal in the wall that eventually makes its way back to the grounding metal in the circuit breaker?
The chair is not grounded and certain fabrics (clothes and the chair) generate static electricity.  OTOH, if the humidity is high enough and the fabric doesn't generate static, the chair might be fine.  That's the way I have been doing electronics - forever.
I visited Minneapolis a couple times and it was possible to draw a large visible arc just approaching a file cabinet.  The humidity was probably 0 since it was below 0 deg F outside.  I would absolutely wear a wrist band if I worked there.
You can just touch the BNC connectors on your scope to drain off any charge on your body.  The thing is, it's hard to remember to do that.  Not really a workable solution.
The humidity around here stays fairly high so I can get along with pretty poor practices.
The following users thanked this post: AnyNameWillDo
Offline bitseeker
« Reply #201 on: August 07, 2018, 03:24:32 am »
This.
A grounding wrist strap has a resistor (~1M) to prevent excessive current and is connected to earth ground via wire to the ground pin on the power outlet (or a grounded instrument's enclosure, ground jack, etc.). Of course, the outlet would have to be properly grounded as well.
If you have a static dissipative mat, it may have a snap or jack to connect a wrist strap to.
Otherwise, for working with stuff that isn't very static sensitive, touch the metal enclosure of a grounded instrument, computer, or similar to discharge any static before touching. When the air is particularly dry and static-prone, I do this "equalizing" before I touch anything electronic including my laptop to avoid zapping them.
Offline rstofer
« Reply #202 on: August 07, 2018, 03:57:46 pm »
That 1M resistor is in the wrist strap circuit to protect the user from being solidly grounded should they happen to put their fingers in the wrong place.  The mat and the wrist strap need to conduct but just barely.  A solid copper work surface would not be a good idea.
Offline AnyNameWillDoTopic starter
« Reply #203 on: August 07, 2018, 04:43:39 pm »
Separate question, but power strips -- will anything pretty much suffice? e.g. https://www.amazon.com/Tripp-Lite-Protector-INSURANCE-TLP602/dp/B00006B82A/
Offline Old Printer
« Reply #204 on: August 07, 2018, 04:50:45 pm »
Has anyone ever heard of someone collecting on one of these "insurance policies"??  I think it's pure BS.
Offline llopis
    • Games from Within
« Reply #205 on: August 07, 2018, 07:44:19 pm »
I really like power strips that can be screwed on to mount on walls/tables/shelves. It's so much nicer to have those plus screwed on and at a usable height!
Offline nanofrog
« Reply #206 on: August 07, 2018, 08:09:30 pm »
Seconded.  :-+
I use a Tripp Lite 20 outlet.
« Reply #207 on: August 07, 2018, 08:10:04 pm »
Ended up getting two of these: https://www.amazon.com/gp/product/B00006B82M/
Offline ez24
  • L.D.A.
« Reply #208 on: August 07, 2018, 08:40:08 pm »
« Reply #209 on: August 07, 2018, 10:04:16 pm »
So for whatever reason the demagnetizer isn't working... and in fact, it seems to magnetize.
« Last Edit: August 08, 2018, 08:47:45 pm by AnyNameWillDo »
Offline tooki
« Reply #210 on: August 07, 2018, 10:16:32 pm »
Try using it like so:
https://youtu.be/Z0gAdLvlrHA
Of course, I assume your goal is to have the screwdrivers magnetized.
« Reply #211 on: August 07, 2018, 10:19:23 pm »
Yeah, the magnetizer area works perfectly fine -- but the demagnetizer does not actually seem to demagnetize. And in fact (as shown in the video), it actually seems to magnetize, i.e. both areas are (ostensibly) magnetizers.
Offline tooki
« Reply #212 on: August 07, 2018, 10:21:48 pm »
Are you trying it as shown in the video I shared? You were doing it differently in your video.
P.S. I think you mean “apparently”, not “ostensibly”! ;)
« Reply #213 on: August 07, 2018, 10:23:37 pm »
Yes, I tried it like in the video as well (have done all sorts of variants based on videos I've seen online).
ostensibly = "apparently or purportedly, but perhaps not actually."
i.e. I'm allowing myself the possibility of being wrong :P
Offline tooki
« Reply #214 on: August 07, 2018, 10:25:52 pm »
What I noticed is that you only went in with the tip in the demagnetizer when moving back and forth. Forget the sideways wiggling, just go in and out, full length...
Offline tooki
« Reply #215 on: August 07, 2018, 10:29:41 pm »
(The difference between “apparently” and “purportedly” is that the former has to do with what’s actually happening, whereas the latter has to do with what’s being claimed. “Ostensibly” doesn’t work in your case because the demagnetizer section doesn’t claim to be a magnetizer. It appears to be acting as one despite its claim to the contrary. Sorry, language nerd here! :p )
« Last Edit: August 08, 2018, 01:16:06 am by tooki »
« Reply #216 on: August 07, 2018, 10:46:14 pm »
Looked around online, right you are, TIL!
Offline tooki
« Reply #217 on: August 08, 2018, 01:15:46 am »
Hahahaha, I just re-read this and man, does it sound like something Beavis and Butthead would be giggling like idiots to…  ;D
Did you manage to demagnetize the screwdriver?
Offline ocw
« Reply #218 on: August 08, 2018, 03:15:44 am »
You previously mentioned getting some old standard parts which you can use as throw-away items.  While that is okay, you need to get some cutting edge parts as well so that you know more than what an outdated part to do.  You need to know how technology has evolved, not just where it started.
I purchased an ADA4530-1 op amp as soon as I saw it, without having any initial plans for it.  I experimented and came up with my own design of a current to voltage converter which permitted accurate measurement of down to below one pico-amp DC current with negligible insertion resistance.  While not designed to maximize its AC performance, it did a reasonable job in that conversion as well.
Long ago, I received a sample NE5534 op amp shortly after it was released stateside.  Attached is the New Product Bulletin that came with it.  Besides listing its Features and Product Strengths, it also includes a Suggested Sales Presentation listing its benefits over the 741.  You can see what they had to do on their bulletin when they couldn't enter a Ω symbol on their bulletin.  While not my first NE5534, I also included a look at the oldest one which I still have in spare parts bin.  It has a 7924 date code on it.  The New Product Bulletin doesn't have a year on it, but I think that it was 1977.  I used a lot of those in building audio amplifiers for production rooms which needed their 600 ohm capability.  It was the op amp to use for those type of projects for many years.  The dual version, NE5532 was released a bit later.
Like the 741, things have progressed since the NE5534 was first released and there are better options for low impedance audio use.  But, its replacements are not nearly as much improved as the replacements for the 741 typically have been.
« Last Edit: August 08, 2018, 03:31:17 am by ocw »
« Reply #219 on: August 08, 2018, 03:42:53 am »
 :-DD
Sadly no
« Reply #220 on: August 08, 2018, 03:24:16 pm »
What's a good pair of strong cutters? Something capable of cutting thicker cords, possibly even PCB boards, maybe steel? Just a nice pair of "cut-anything"s.
Offline tooki
« Reply #221 on: August 08, 2018, 04:02:49 pm »
No such thing, I'm afraid, since those have totally different needs! For thick cords, you want cable shears. For PCBs (assuming you don't wanna spend 3-4 digits on a PCB guillotine), you want large tin snips.
« Reply #222 on: August 08, 2018, 04:06:46 pm »
I had been looking at stuff like this:
Cable Shears: https://www.amazon.com/KNIPEX-95-11-165-Shears/dp/B000X4MQ8C
Tin Snips: https://www.amazon.com/Stanley-FatMax-14-563-Straight-Aviation/dp/B00009OYFY
Anything better / are these appropriate?
Offline tooki
« Reply #223 on: August 08, 2018, 04:17:09 pm »
I think it's very unlikely you need cable shears. I've been doing electronics for 30 years and still don't own a pair. The thickest wire I ever cut is AC line cords (3x16ga if you're lucky), and those cut fine, if a tad smushed, with the cutters in pliers, or with diagonal cutters. (Not your delicate electronics side cutters, but the ones like in the cheap pliers set you mentioned in one of your earliest posts.)
As for tin snips, probably go bigger, so you can cut a PCB across in one cut if possible. I suggest just going to Home Depot and checking out the options. (Or waiting for others here with more experience to give you feedback. Tin snips for PCB cutting are still on my shopping list.)
« Reply #224 on: August 08, 2018, 04:32:24 pm »
Yeah, AC line cord is exactly what I had in mind, actually (assuming I understand correctly) -- like if I needed to cut the cord to an appliance or something. I don't think I have a pair of "diagonal cutters" though.
I was just at Home Depot the other day looking for such cutters and all they had were things along the same size, lol.
