Author Topic: My understanding of the cause of common mode noise in my measurement  (Read 363 times)
Offline eTobeyTopic starter
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
i have read a bit, drawn my circuit and started thinking. Because i did not comprehend why the noise was exactly generated in the scope/circuit, even though i had the probe shorted.
Now i have come a conclusion and would like to know if this is true, and if there are other circumstances where this would be not the case or somehow different:
"The noise is generated by a current that flows through the GND lead of the probe (through earth GND back to the supply and its parasitic capacitances), and therefore creating a voltage."
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
My current top list of issues on the SDS800X HD:
https://www.eevblog.com/forum/testgear/sds800x-hd-bug-reports-firmware/msg5766323/#msg5766323
Offline m k
Re: My understanding of the cause of common mode noise in my measurement
« Reply #1 on: December 28, 2024, 02:18:25 pm »
Practically everything is an antenna of some sort.
So everything must be filtered somehow also.
If your shorted probe is showing a shape of a line voltage it is not shorted to neutral.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
« Reply #2 on: December 29, 2024, 02:26:48 pm »
Neutral? You mean earth ground?
Offline m k
« Reply #3 on: December 29, 2024, 04:12:06 pm »
More like a point the PSU treats as neutral.
It can still be "far" from real earth.
When you short the probe you still have a triangle of probe leads and a circuit at the other end.
Some say that for 4-wire measurement you should have all leads disconnected from the bundle.
I guess that starts to be around a magic category.
