Author Topic: Mysterious LED  (Read 1901 times)
Offline Lucky-LukaTopic starter
Mysterious LED
« on: April 16, 2021, 02:25:12 pm »
Hi all
I've analyzed an LED taken from a votive candle.
Why is it flickering (they do that to remeber the fire of wax candles)? What's inside of it?
https://youtu.be/opU5CsuhHgA
Thanks
Memento audere semper.
Online exe
  • self-educated hobbyist
Re: Mysterious LED
« Reply #1 on: April 16, 2021, 02:38:50 pm »
There is an IC driver doing that. I didn't find a die shot of what you have, so I propose to look at ws2812 die shot: http://mirekk36.blogspot.com/2013/09/co-to-jest-czyzby-powrot-do.html .
If you are curious about die shot, check this website: https://richis-lab.de/Bipolar20.htm . Or check posts from Noopy on this forum. Like https://www.eevblog.com/forum/projects/lm723-die-pictures/
The following users thanked this post: natman69, AmnevaR, Lucky-Luka
Offline Zero999
  • 0999
Re: Mysterious LED
« Reply #2 on: April 16, 2021, 06:43:45 pm »
Noopy's thread on optoelectronics is interesting.
https://www.eevblog.com/forum/projects/optoelectronics-die-pictures/
Offline floobydust
Re: Mysterious LED
« Reply #3 on: April 16, 2021, 06:48:42 pm »
I saw Ikea LED candles all flickering exactly the same. I shut them off and then turned them on at the same time, and they were all synchronized.
They seem to be reading a pattern in ROM and just cycling through it. That should be part of the IC in OP's LED.
Online Gyro
Re: Mysterious LED
« Reply #4 on: April 16, 2021, 06:56:38 pm »
After seeing some rumours on the web, I tried hooking a piezo sounder across the leds on a bunch of old LED candles (COB rather than embedded in the LED). A few types did indeed play nice little oriental tunes - clearly dual use greeting card ICs. Others just produced nasty random noise, so at least some have (had) ROM lookup.
Best Regards, Chris
Re: Mysterious LED
« Reply #5 on: April 16, 2021, 07:34:55 pm »
Can you explain better what you have done?
It's amazing (for me) the technology hidden in these cheap LEDs!
Offline edavid
Re: Mysterious LED
« Reply #6 on: April 16, 2021, 07:37:54 pm »
« Last Edit: April 16, 2021, 07:41:18 pm by edavid »
Offline DrG
Re: Mysterious LED
« Reply #7 on: April 16, 2021, 09:12:47 pm »
We had a thread earlier that wandered into those little electronic candles - your pic was similar to mine https://www.eevblog.com/forum/chat/a-burning-candle-in-epoxy-resin/msg3106588/#msg3106588
Those little things do a poor job of simulating a candle flicker. If you are interested, check out this guys attempt https://cpldcpu.wordpress.com/2016/01/05/reverse-engineering-a-real-candle/ very well thought out and analyzed in my view.
- Invest in science - it pays big dividends. -
The following users thanked this post: edavid, Lucky-Luka
Offline amyk
Re: Mysterious LED
« Reply #8 on: April 17, 2021, 04:10:14 am »
I once saw some extremely cheap "flickering candle" lights that had a curiously short and repetitive pattern: three short blips, then three slightly longer blips. ::)
Online Gyro
Re: Mysterious LED
« Reply #9 on: April 17, 2021, 08:56:30 am »
Oh yes, that famous little oriental tune: https://en.wikipedia.org/wiki/F%C3%BCr_Elise
https://www.instructables.com/Listen-to-a-led-tea-light/
Interesting, I would certainly have recognised that one! The tune from mine was definitely oriental in nature, quite delicate. I wonder how many variations there are out there. Presumably only on the older candles.
Best Regards, Chris
Re: Mysterious LED
« Reply #10 on: April 17, 2021, 09:46:34 am »
I've tried with my LEDs but their tune doesn't mean anything :(
Offline Twoflower
Re: Mysterious LED
« Reply #11 on: April 17, 2021, 10:35:27 am »
My understanding is that flicker LED candles with external chips might play a tune as they re-use sound-chips. LEDs with an integrated flicker chip use specific PRBS chips. Probably the sound chips are too big to fit in a LED housing.
By the way. Here is one candle LED that is a bit more realistic:
Online Gyro
Re: Mysterious LED
« Reply #12 on: April 17, 2021, 11:15:33 am »
Yes, I'm sure the dies integrated into LEDs are optimised for minimum size and best function, rather than re-purposing existing ones.
Best Regards, Chris
Online RoGeorge
Re: Mysterious LED
« Reply #13 on: April 17, 2021, 11:24:54 pm »
At some point I thought it's some 1st April joke.   ;D
Mine were from LIDL, with a single CR2032 batt from around year 2015.
They don't sing, only buzz in single tone pulses.   :-\
Offline james_s
Re: Mysterious LED
« Reply #14 on: April 18, 2021, 03:07:23 am »
The same guy analyzed one of these flicker flame LEDs.
https://cpldcpu.wordpress.com/2013/12/08/hacking-a-candleflicker-led/
The following users thanked this post: Gyro, DrG
Online Gyro
Re: Mysterious LED
« Reply #15 on: April 18, 2021, 09:18:45 am »
The Germans have no sense of humour!  ;D
(Sorry, that was very politically incorrect!)
« Last Edit: April 18, 2021, 09:33:28 am by Gyro »
Best Regards, Chris
