Author Topic: What's the cheapest way to mesure power of RF output(such as wifi router) ?  (Read 776 times)
Offline youta556Topic starter
I want to compare output power of 2 wifi routers.
Both 2 routers have sma antenna ports.
I have no professional power meter such like keysight V3500A,bird 43.
Offline cdev
Hi! Welcome to eevblog!
A wifi router's power output is very small and high enough in frequency (2.4 GHz ) that measuring it is likely fairly difficult.
A directional coupler might help. I was able to get a field strength meter to deflect.. It used an 1N34 diode as its detector.
A dummy load might help.. a non-reactive 50 ohm resistive load..
Which router has an SMA jack for its output?
« Last Edit: April 21, 2022, 07:48:27 pm by cdev »
Online Ice-Tea
    • Freelance Hardware Engineer
Decent chance you'll find they are the same or very comparable. There's a regulatory limit. Unless you're taking bottom dollar units, you can be pretty sure they're turned up as far as allowed.
Offline cdev
MiniCircuits sells power detector modules that may be exactly what you want, giving you what is in effect a sensitive RF power measurement device.
Offline dcarr
Search eBay for "crystal detector sma" and "diode detector sma".
These accept RF on the input SMA and produce a voltage proportional to the power in dBm on the output connector.  You can read them out with a voltmeter for steady signals or with a oscilloscope for pulsed signals.  It looks like there are options from $30-70 that would work at 2.4GHz.
Offline ledtester
Two "out of the box" ideas...
1) a "wifi signal strength" phone app; I have one that shows dBm -- might be good enough for at least a comparison
2) look up the test results filed with the FCC; go to https://fccid.io/<FCC ID>, e.g.:
https://fccid.io/W5HSBG6580
Offline dcarr
This is clever.  I like it.
