Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Mystery Resistor
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Mystery Resistor (Read 864 times)
cscott242
Newbie
Country:
Mystery Resistor
on:
April 15, 2023, 01:09:16 am »
Can someone tell me the watts of this resistor?
Thank you in advance if you help me.
I don’t know the voltage.
Brown, Black, Red, Black?
Logged
Jwillis
Super Contributor
Country:
Re: Mystery Resistor
Reply #1 on:
April 15, 2023, 01:44:30 am »
Difficult to say without a point of reference to size. Measure the diameter and length of the body. But going by the wire size it looks like 1/4 watt.
Logged
barshatriplee
Regular Contributor
Country:
Reply #2 on:
April 15, 2023, 11:23:49 am »
The size looks like 1W to me.
Logged
Zero999
Super Contributor
Country:
0999
Reply #3 on:
April 15, 2023, 11:31:26 am »
Without knowing the size, it's impossible to tell. It appears to be made of a ceramic material. so will be able to tolerate a higher temperature, thus more power, than a carbon or metal film resistor of the same size.
Logged
cscott242
Newbie
Country:
Reply #4 on:
April 15, 2023, 01:07:24 pm »
Thank you very much! Here is a more logical pic.
Logged
Zero999
Super Contributor
Country:
0999
Reply #5 on:
April 15, 2023, 02:10:20 pm »
Quote from: cscott242 on April 15, 2023, 01:07:24 pm
Visit an electronic component distributor's website.
Go to the section of the site for through hole resistors.
Select axial and the dimensions of the component, about 12mm in this case.
Look at the results.
Here's an example showing Farnell's website.
https://uk.farnell.com/w/c/passive-components/resistors-fixed-value/through-hole-resistors?resistor-case-package=axial-leaded&product-length=12mm
It's probably either 1W, or 2W, depending on whether it's carbon film, or metal oxide/wire wound. Going by your picture, it's probably not carbon film, so the power rating will be 2W. Note that, if you intend to use it anywhere near 2W, then it will get very hot and should be mounted on stand-offs, so as to avoid burning the PCB.
Logged
Vovk_Z
cscott242
Newbie
Country:
Reply #6 on:
April 15, 2023, 04:05:26 pm »
Wow. Thank you very much. This is amazing that this site exists and you helped me. Thank you
Logged
Gyro
Super Contributor
Country:
Reply #7 on:
April 15, 2023, 06:41:33 pm »
What was the reason for you removing the resistor? Has it gone open circuit? If so, it might be a fusible resistor, designed to open safely to protect against fire under circuit fault conditions. A little background might be helpful.
Logged
Best Regards, Chris
Wallace Gasiewicz
Super Contributor
Country:
Reply #8 on:
April 15, 2023, 08:50:59 pm »
Usually fusible resistors have the last band in the color WHITE
Wire wound resistors have the last color BLACK
The exterior construction also suggests a wire wound.
Logged
Gyro
Super Contributor
Country:
Reply #9 on:
April 15, 2023, 09:13:31 pm »
Sure. It's worth checking though, this is the beginners section and we don't have any context to go on.
Logged
Best Regards, Chris
Wallace Gasiewicz
Super Contributor
Country:
Reply #10 on:
April 15, 2023, 09:59:24 pm »
Yea, if the resistor is "open" then perhaps chipping away some of the surface would reveal some wire.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Mystery Resistor
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
