Author Topic: how would an AC power meter from the 1940s or so have worked?  (Read 1275 times)
Offline dkterTopic starter
« on: September 05, 2022, 03:56:06 pm »
not sure if I'm posting this in the right place. I fell into a bit of a rabbit hole recently and am now in way over my head trying to research things that I have no idea how to begin looking for.
I'm wondering how a device that measures RMS power would have worked in the days before semiconductors and bridge rectifiers. Any pointers would be helpful
Offline capt bullshot
Re: how would an AC power meter from the 1940s or so have worked?
« Reply #1 on: September 05, 2022, 04:00:30 pm »
They just work by computing i(t)*u(t) the analog way:
Some of them really are mechanical wonders ...
The following users thanked this post: dkter
Online oPossum
« Reply #2 on: September 05, 2022, 04:54:13 pm »
Offline TimFox
« Reply #3 on: September 05, 2022, 05:00:21 pm »
One of my pet peeves:  "rms power".
If you measure the rms voltage V across a known resistance R, then the mean power is V2/R.
This is true for any waveform, including DC and an AC sine wave.
As an exercise for the reader, you can compute the "rms power" for a sine wave, which is 22.5% larger than the mean power, but is a useless parameter.
With a device that measures the instantaneous value of the voltage V(t) and the current I(t), then their product W(t) = V(t) x I(t) is the "instantaneous power", and the time average of that power as a function of time over a long time is the mean power, corresponding to the meaning above for a voltage and resistor.
« Last Edit: September 05, 2022, 05:09:24 pm by TimFox »
Offline Gyro
« Reply #4 on: September 05, 2022, 06:01:48 pm »
AC power meters were actually quite easy... Back in the 1920s when DC mains was more or less universal, there were all sorts of ingenious integrating electricity meters (attached). These included unipolar motors (Mercury bath), Mercury electrolytic Coulomb meters (a hugely upscaled version of the much more recent fuse sized Mercury column elapsed time indicators), and even DC brushed motors. Each worked on the voltage drop across a large shunt resistor. I think the voltage was assumed to be constant or, at least, ignored (the customers wouldn't have known back then). These devices have been virtually forgotten! I've never seen any of them in the flesh - they would have been scrapped by the electricity companies when they changed to AC mains.
AC services (usually industrial 3-phase back then) used the more recognisable dual coil eddy current discs, as featured in the videos above. In the case of 3-phase, all of the discs appear to have been mounted on a common shaft. Presumably the loads were mostly motors, with balanced load across the phases.
« Last Edit: September 05, 2022, 06:25:21 pm by Gyro »
Best Regards, Chris
Offline james_s
« Reply #5 on: September 05, 2022, 06:12:55 pm »
Many modern meters still work exactly the same way as 1940s meters. Many of the "smart" meters are just a standard meter with some additional electronics tacked on to enable real time monitoring of consumption. The meter I have now appears to be solid state but up until about 3 years ago it had a spinning disc just like the antique meters, with a little sensor to count the revolutions.
Offline armandine2
« Reply #6 on: September 05, 2022, 06:26:01 pm »
https://www.academia.edu/8140873/A_K_Sawhney_A_course_in_Electrical_and_Electronic_Measurements_and_Instrumentation
chapter 10 of Sawhney I believe has the electrodynamic wattmeter
I got to use my old wattmeter following a YT tutorial in Hindi(?)
Ed . added photos
« Last Edit: September 05, 2022, 06:41:11 pm by armandine2 »
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
Offline MrAl
« Reply #7 on: September 05, 2022, 08:12:15 pm »
Not sure what date this is from but one of them used resistors to measure the power due to the heat created when a current runs through a resistance.  They used that to measure RMS current.
Offline TimFox
« Reply #8 on: September 05, 2022, 08:15:27 pm »
“Thermocouple ammeters” were common ca. WW II for measuring RF current at transmitter outputs or antennas.
Offline Terry Bites
« Reply #9 on: September 05, 2022, 10:05:47 pm »
These electromechanical meters into use about 1900.
Ancient reliable tech.
For a not too deep dive see https://www.electricaldeck.com/2021/05/induction-type-energy-meter-construction-working.html
Offline mag_therm
« Reply #10 on: September 06, 2022, 12:19:37 am »
From about 1970 onwards, the brides' mothers were very demanding for true RMS.
Others didn't' care.
Free libations tomorrow for the first correct answer... why?
« Reply #11 on: September 06, 2022, 03:57:17 am »
Thanks for all the resources! Super helpful.
I'm trying to figure out the rationale for the marketing of this specific meter from 1950:
(this is an article describing the eponymous "diotron" circuit, for anyone interested)
The ad seems to insinuate that these standard analog power meters can't handle arbitrary waveforms. Why is this?
From what I can tell, these analog meters smooth out the AC waveform mechanically by storing energy in the coiled spring, which can later release it and average out the power over a small period. I don't see why this action would be dependent on a sinusoidal waveform. Do I have the wrong idea here?
Offline jonpaul
« Reply #12 on: September 06, 2022, 04:32:14 am »
Thomas Edison...1880s, plating weight in electrolyte cell, meter shunt
1900s..1970s special motor with current and voltage coils, number of turns proportion to KWH.
Mechanical counter
1970s..1980s as above but optocoupler counts turns and electronic counter
see the history of electric power meters
J
Jean-Paul  the Internet Dinosaur
