I do not want to disillusion you but if I look at the prices and specifications of for example the jds6600:
https://www.aliexpress.com/wholesale?SearchText=jds6600Then there is no way you're going to get anywhere near those kinds of specifications without a very serious design effort.
And even if you try to design such a thing and you later discover you've been in your lab for months and then have made a thing you can buy for EUR 80 it takes the fun out of it. Even if you get all the parts for free and you've been working / hobbying for 50ct / hour it makes you scratch behind the ears and ask yourself what you're doing.
Old service manuals such as from the Stuff David points to is a good source for information, but when you've sourced the parts, made a PCB and found a housing to put it in it is probably already much more expensive.
I think there is more value / satisfaction in designing some custom gadget for a problem that has no solution yet, or work on a desing to be shared with multiple people (preferably also share the design effort), but those projects are hard to find.
