Author Topic: Need assistance identifying components  (Read 638 times)
Offline Azapp1976Topic starter
« on: December 22, 2019, 05:52:27 am »
Hello EEVblog
This is my very first post on the EEVblog, I am a fairly new electronic hobbyist, I recently picked up some components at a local flea market,
I believe that some of these components are diodes or resistors, however some are 2 band and there are no 2 band resistor calculators or color charts
that I can find. I would like to find out the values of these components.
If anyone could help me identify what these components are by looking at the photographs.
thanks
Online Psi
Re: Need assistance identifying components
« Reply #1 on: December 22, 2019, 06:13:51 am »
Hard to be sure without measuring them because they are old/non-standard, but my guess is they're inductors.
« Last Edit: December 22, 2019, 06:15:31 am by Psi »
Offline WattsThat
« Reply #2 on: December 22, 2019, 06:16:16 am »
Inductors, not resistors, based on body color and number of value bands. You can see the exposed wire on #3/4/5.
1 & 2 are molded, 3/4/5 are open wound, #6 or “Diode-01” is definitely a blank form for hand wound inductors, typically RF chokes since the values will be in the low micro henry ranges and not usable for much else than RF applications. It was common back in the vacuum tube days to wind your own chokes on carbon comp resistors, similar to what you see in 3/4/5.
