Author Topic: Problem with TC7107 LED Display Driver  (Read 4702 times)
Offline king.osloTopic starter
  • Country: no
« on: November 11, 2011, 05:44:28 pm »
Hello there :D
I've got a TC7107 wired like in the "typical application" in the data sheet.
The only modifications I made is to use different Vref+ and Vref - (+2.5V and 0V), and I changed the RC values of the RC oscillator to 680pF and 3.3kOhm (I should get crica 200.53kHz)
The problem is that the 3 1/2 display is displaying: "1    ". Basically a "1" in the 1/2 segment, and nothing in the other three. The LEDs are wired correctly, because when I pull the TEST pin high, all segments light up.
I tried to measure the legs of capacitator with a scope with respect to GND. I expected to see a waveform, but I cannot see one, other than perhaps some noise.
How do I go about troubleshooting the TC7107 to find the fault?
Datasheet can be found here:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010503
Thanks.
Kind regards,
Marius
« Last Edit: November 11, 2011, 05:48:47 pm by king.oslo »
Offline david77
Re: Problem with TC7107 LED Display Driver
« Reply #1 on: November 11, 2011, 06:33:23 pm »
Are you shure it's not just indicating overflow? The classic ICL7107 do that by displaying "1".
Offline Balaur
« Reply #2 on: November 11, 2011, 06:46:32 pm »
Assuming that everything is connected correctly, it looks to me that the clock is not starting.
I'm very sorry to be a bit condescending, but judging by your previous questions on this subject, I cannot help myself to not ask you:
Which part of the following sentence of the datasheet have you not understood:
ROSC (Pin 40 to Pin 39) should be 100 k.
You have used 3K3. Surely, there is a bit o discrepancy, don't you think?
Please try to implement the recommended schematic to verify that everything works correctly, then you'll have all the time you want to be creative.
Cheers,
Dan
  • Country: no
« Reply #3 on: November 11, 2011, 08:29:10 pm »
« Last Edit: November 11, 2011, 08:53:20 pm by king.oslo »
  • Country: no
« Reply #4 on: November 11, 2011, 08:29:55 pm »
David, I don't know.
Voltage between Vref pins are 2.5V. Should give a range of 5V across the 2000, counts, right?
Voltage between In+ and In- are 0.48V, so I expected the display to say 192 :)
Do you agree with this?
Cheers,
Dan
Thanks Dan,
I did what you said. Still no waveform between the capacitator and GND. As said previously, there is something that looks like noise, however. The amplitudes are about 10mV, so I expect that it isn't the clock signal?
Thanks.M
« Last Edit: November 11, 2011, 08:54:37 pm by king.oslo »
Offline Balaur
« Reply #5 on: November 11, 2011, 11:34:14 pm »
The clock signal should be observed on OSC3.
You could try the following:
- zero the input voltage (i.e. connect IN HI with IN LO): the indication should be 0000.
- pull the "TEST" (connect it to V+). All the led segments should be lit
If none of these checks work, and assuming that the circuit is implemented correctly, a (very unlikely) explanation could be that somehow the oscillator buffers have been damaged by the low Rosc.
  • Country: no
« Reply #6 on: November 11, 2011, 11:56:06 pm »
- There is nothing there.
If I connect them together, the display still says "1   ".
This works as intended. This displayes "1888".
Once I get some 100pF caps, I will solder everything exactly like the datasheet suggests, and see if that helps.
Unless you have some more thoughts.
Thanks.
Kind regards,
Marius
