Author Topic: High pitched noise from USB charger - fixable?  (Read 1242 times)
Offline atmfjstcTopic starter
« on: November 30, 2020, 03:28:56 pm »
I have an Allocacoc Power Cube - basically an extension socket with 2 USB ports included - that makes a very annoying intermittent high-pitched sound while charging most devices. The sound is clearly correlated to the power draw and well within hearing range, I'd estimate about 13kHz or so. I think it always used to be there, but it seems to have become much more noticeable lately.
I imagine the DC conversion circuitry in the socket isn't great, but still it's very convenient and I'd like to fix it if possible instead of buying a dedicated charger. Does anybody know if this is possible? Could it be something like a damaged capacitor, or is it a fundamental design flaw?
Offline Yansi
  • STM32, STM8, AVR, 8051
Re: High pitched noise from USB charger - fixable?
« Reply #1 on: November 30, 2020, 03:33:22 pm »
This gets fixed the easiest way by buying a good quality charger.
Offline Refrigerator
  • Country: lt
« Reply #2 on: November 30, 2020, 04:06:22 pm »
Transformer coil whine is too much trouble to be worth fixing.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline Yansi
« Reply #3 on: November 30, 2020, 04:45:37 pm »
Correction: Phone chargers are not worth fixing. You'll easily spend more resources trying to fix the cheap sh!t than what you'd need to buy new decent one.
