Electronics => Beginners => Topic started by: Undweeber on May 30, 2020, 04:56:54 pm
Title: Need help driving 36V LED
Post by: Undweeber on May 30, 2020, 04:56:54 pm
First of all, here is the data sheet https://download.luminus.com/datasheets/Luminus_CXM-27_GEN1_Datasheet.pdf
My exact LED is 2700K and 95CRI and I am very confused.
CXM-27-27-95-36-AA00-F2-2
1. It’s listed as 36V LED, and at 1.8-2A it’s around 60W, but I’m not sure if it’s constant current or constant voltage and what it means.
2. I don’t want to run it at 60W mainly because I don’t want up deal with so much heat, and bulky radiators, that said I will run it with a small radiator.
3. I would like it to be dimmable so I’d like to know which aspect can I use to dim it, can I control the voltage up and down or Does it require the current to control the brightness?
I REALLY don’t want the PWM flicker, this is one huge dealbreaker for me.. the seller still hasn’t shipped it, ideally I would get a 12V LED and slap a regular constant 1A power supply on it, but these are 36V and I don’t know where to begin.
If it requires 36V to run then I would like to run it at 0.5-1A, I don’t want to run it anywhere close to 2A. If to control brightness I must use PWM then which power supply will have a very high frequency non flickering one? Or could I just drive it with 0.5A 36V power supply without dimming?
Title: Re: Need help driving 36V LED
Post by: Undweeber on May 30, 2020, 06:44:10 pm
I found this unit https://www.ebay.com/itm/adjustable-power-supply-chargers-DC-1-36V-AC100-240V-Converter-adapter-switching/254270142462?hash=item3b33ae77fe:m:m1CC91HyhPCxtTPItlB3abQ (https://www.ebay.com/itm/adjustable-power-supply-chargers-DC-1-36V-AC100-240V-Converter-adapter-switching/254270142462?hash=item3b33ae77fe:m:m1CC91HyhPCxtTPItlB3abQ)
It is variable 24-36V and constant 2A, will it work with this LED?
Post by: Marco on May 30, 2020, 07:04:16 pm
Nah, you want a CC power supply.
Hard to go wrong with Mean Well. They've got a shit ton of different models, you'll want a ~1A model which has an output voltage range around 36V ... the subset you want will be mostly determined how you want to dim it. Some can be dimmed with a potentiometer, some want a 0-10V or PWM signal, some have DALI.
Post by: Undweeber on May 30, 2020, 08:10:52 pm
isn't that a constant current? its rated for 1A and has variable voltage
Post by: Marco on May 30, 2020, 08:17:28 pm
No, it isn't.
Post by: Undweeber on May 30, 2020, 09:04:29 pm
why is it not, it has variable voltage and doesn't put out more than 1A, please help me understand, I never met this kind of problem before, and while the terminology seems logical, I seem to be missing something.
What is exactly the issue with the linked power supply? I cant find a single CC AC to DC that could put out 36V and be dimmable, i went on MeanWell and cant seem to understand which one would work...
thanks for helping..
can i install an inline potentiometer to control the brightness in the CC setup? will it control the current? what do you mean by the word subset?
Post by: Marco on May 30, 2020, 09:39:26 pm
It's not designed to be CC, you have no idea how it's current limit works. It's not like it has a datasheet, or a known manufacturer. it could just be thermal protection or fold back, or anything. It's a variable voltage power supply, even if it has a decent steady current limiting trying to dim it by adjusting voltage is not stable (because at that point it will no longer be current limiting).
Mean Well HLG-40H-42 for instance can have it's current limit adjusted with a potentiometer and will drive your LED.
PS. also the Mean Well is far less likely to burn your house down.
Post by: Undweeber on May 30, 2020, 09:45:36 pm
what does 0-10V dimming mean? I found this thing https://www.ebay.com/itm/ERP-ERM060W-1750-40-dimmable-constant-current-LED-driver-60w-1750mA-40Vdc/233049066057?epid=1625576&hash=item3642ce8a49:g:JbMAAOSwpLdcFdtX (https://www.ebay.com/itm/ERP-ERM060W-1750-40-dimmable-constant-current-LED-driver-60w-1750mA-40Vdc/233049066057?epid=1625576&hash=item3642ce8a49:g:JbMAAOSwpLdcFdtX)
its a bit too much power than I need but I would just have to be careful with it
Mean Well is a bit too expensive.. and it says it has no dimmer on the page.
Post by: Marco on May 30, 2020, 09:56:15 pm
It means it expects a 0-10V signal to determine the current for the LED, practically this will probably mean you want to buy a 0-10V dimmer switch.
Ignoring that, it does look like a decent power supply for your LED.
Websites are shite, what else is new. Just read the datasheet instead. It allows PWM dimming, 0-10V dimming and potentiometer dimming.
PS. even at 1A the LED will need a heatsink BTW.
Post by: Undweeber on May 30, 2020, 10:24:48 pm
thank you again, I know it will need a heat-sink
as per dimmer itself, how does it interface with the driver, I am very much wishing i just go 12V, but the issue is that good quality LED's seem to come at higher voltages, and this is proving to be such a pain in the ass
can you suggest on how to dim? is it like a separate module that plugs into the dimmer wires?
Post by: Marco on May 30, 2020, 10:45:42 pm
Yes.
https://www.amazon.com/0-10v-dimmer/s?k=0-10v+dimmer (https://www.amazon.com/0-10v-dimmer/s?k=0-10v+dimmer)
Post by: Marco on May 30, 2020, 11:14:15 pm
Actually, the datasheet says you can dim the ERP power supply with a resistor/potentiometer too.
https://www.erp-power.com/wp-content/series-assets/erm-series/datasheet-long/erm-series-datasheet.pdf (https://www.erp-power.com/wp-content/series-assets/erm-series/datasheet-long/erm-series-datasheet.pdf)
A 10K potentiometer is not as pretty as a wall dimmer switch, but a lot cheaper.
