Author Topic: Need help fixing my computer screen. Capacitor values?  (Read 3041 times)
Offline tczTopic starter
« on: April 09, 2021, 08:02:55 pm »
Hello,
I'm trying to repair my Dell G2410T LCD monitor. The power light turns on green but the screen is completely black. Sometimes it's just the backlight and you still see a dark image but it didn't seem to be the case.
So far I opened up the monitor and took the electronics out.
I found:
-A larger power supply board roughly 6 inch * 6 inch
-A smaller board with all the video outputs on
-A even smaller board which I believe drives the backlit... forgot what those were called.
At first sight everything looks good, nothing is burned and all the caps have a flat top.
Using a TC1 tester (one of those cheap lcr esr tester) I tried to test the Caps in circuit... when that failed :palm: I undersold all the caps on the power supply and tested them individually.
I got the specs from the manufacturer to compare the results but I must admit: I don't quite know what to make of my readings, when are the values too far off that they should be replaced?
In the attached image the first COLUMN is the manufacturer's  specifications, the others are individual caps grouped by Type.
1209556-0
I could use some pointers.
Thank you for reading.
« Last Edit: April 09, 2021, 08:46:48 pm by tcz »
Re: Need help fixing my computer screen. Capacitors?
« Reply #1 on: April 09, 2021, 08:39:36 pm »
For some reason I'm unable to modify my post so here is some extra info as a reply:
Turns out the small PCB is the Inverter, one of the stickers on the back has yellowed. Maybe it got slow cooked over time, not sure if it indicates a problem.
I attached extra pictures of the FRONT and BACK of each boards.
Here is where I took the specs for the caps: https://su-scon.com/wp-content/uploads/2021/01/Su-scon-Catalog_2021.pdf
Thank you.
« Last Edit: April 09, 2021, 08:49:25 pm by tcz »
Offline james_s
Re: Need help fixing my computer screen. Capacitor values?
« Reply #2 on: April 09, 2021, 08:48:39 pm »
A couple of those capacitors look a little marginal, but nothing really jumps out at me as bad. Did you check the voltages of all of the power supply outputs? Often the correct voltage is printed on the board by the connector, but sometimes you have to guess.
The following users thanked this post: tcz
« Reply #3 on: April 09, 2021, 08:53:43 pm »
No that was my next step, should have been the first...  |O
I will re-solder everything and test voltages.
Offline Jwillis
« Reply #4 on: April 09, 2021, 11:00:17 pm »
Back light Driver boards are usually the first things to go on LCD and LED displays.
The small board is the LED driver using the OZ9967  OZ99XX . See page 28. Check the power on the 7 pin connector with 6 wires. Black and possibly Brown will be common grounds and/or reference grounds . Red and possibly Orange will likely be power wires. Yellow and Green are likely to be signal wires Dim and power On/Off . Check those voltages . If those look good check the six transistors on the driver board . I can't see the numbers on those . Check for voltage at the Base of those transistors . If no voltage then the Driver is either not turning on or broken . Trace  pin 19 on OZ9967 back to the 7 pin connector and check for signal voltage when power on and power off . If that DOES NOT work the problem is likely on the control board. If you get a signal on the on/off then the driver OZ9967 is not functioning. Careful not to short any pins or connections .
Also check F101 (fuse) top left black resistor looking thing with a 0 .
If the driver and everything else seems fine then check the Mosfet Q101 for possible failure.
Fixed spelling and an error! Please reread
« Last Edit: April 10, 2021, 04:26:43 am by Jwillis »
« Reply #5 on: April 09, 2021, 11:59:47 pm »
I will test all of this over the weekend.
Thank you very much for all the info!
« Reply #6 on: April 10, 2021, 01:22:41 am »
I tested the voltages going from the power supply to the inverter and the video output board.
All the 3.3v, 5V and 18V pins are at the proper voltage.
On those connectors there were pins labeled "off", "on/off" and "BRI". Not sure how to test those.
I will now try to troubleshoot the inverter board as described by Jwillis.
« Reply #7 on: April 10, 2021, 04:04:32 am »
Here is a a close up of the OZ99xx chip and the transistors.
Are those holes on the transistors??? They all look the same except for one that doesn't seem to have a hole in the "dot" of the marking.
« Last Edit: April 10, 2021, 04:24:17 am by tcz »
Offline Jwillis
« Reply #8 on: April 10, 2021, 05:02:18 am »
2T  General Purpose Transistor (PNP)
Can you make a diagram of the readings you got on the connector.
Pin 19 on the driver either goes high or low on turn on . Connect your DMM to the appropriate wire on connector that traces to pin 19 and see if it goes high or low on turn on . That's the On/Off  . The data sheet doesn't show any voltages for that chip. I'm guessing it should go high when referenced from ground. Not familiar with that driver chip.
The remaining wire should trace to pin 23. I believe that is the brightness.This will control the output duty cycle of the driver.
Getting voltage readings on those  transistors would be easier on a scope .
Q101 is the driver MOSFET and the six transistors sink current to ground via the LED strings. If that MOSFET fails or if there is no signal to the gate  there will be no supply current to the six LED strings. If there is no signal to the gate then its the driver chip or the inductor has failed.
Basically work your way from problem (no lights) back towards the driver chip.
 It's to bad the manufacture of that driver chip is so secretive and won't show typical operating values. Unless some one else has a better data sheet kicking around.
« Reply #9 on: April 10, 2021, 05:05:25 am »
I will work on it.
In the mean time I connected my T1 tester to the 6 transistors and got those readings:
(They were all identified as BJT-PNP)
hFE=   39         39         40         40         39         39
Ube=  656mV  654mV   656mV  652mV  653mV   653mV
Ic=      6.0mA   6.0mA   6.0mA   6.0mA   6.0mA   6.0mA
I'm not sure what to compare those values up against, am I correct to assume I wouldn't get a reading if they were fried?
« Last Edit: April 10, 2021, 05:33:00 am by tcz »
« Reply #10 on: April 10, 2021, 05:20:45 am »
If you mean the connector for the cable coming from the power supply (6 wires, 7 pin connector):
Black     18v
Brown   18v
Empty
Red       GND
Orange GND
Yellow   BRI
Green   On/Off
Both 18v test at the proper voltage (I was also surprised about the usual GND and Voltage colors been reversed but the markings on the PCB itself confirm this)
Unfortunately all I have is a 24mhz 8ch Logic Analyzer, a TC1 tester and few Multi-meters.
A repair manual for a Dell G2410T Monitor may also have valuable info but I couldn't find one of those either.
« Last Edit: April 10, 2021, 05:30:03 am by tcz »
Offline PKTKS
  • Country: br
« Reply #11 on: April 10, 2021, 02:45:17 pm »
Well  I am not sure (even surprised) WHY the folks
are calling a simple LED driver an "inverter" ..
Actually it is not.
Inverters are used on CCFL devices - not LEDs
LED based monitor drivers are just BUCK converters
with some protections.
Usually a peripheral component aged or dead shorted.
LEDs are mostly the culprits.
Why they call that INVERTER?  no clue
Paul
« Reply #12 on: April 10, 2021, 05:14:20 pm »
I'm sure you can get help. But please start your own thread or it will be a mess in here.
« Reply #13 on: April 10, 2021, 05:19:03 pm »
You are totally right, but if you look at the pictures even Dell is calling it an "Inverter board".
It goes back to the first LCDs that used cathodes as their back light.
"Usually a peripheral component aged or dead shorted.
LEDs are mostly the culprits."
You mean some components on the "back light driver" board (aka inverter board) ?
Also, are you implying the LEDs in my LCD panels may be to blame?
This monitor has seen maybe a year or two of use only (even though it's an old model).
« Last Edit: April 10, 2021, 05:50:49 pm by tcz »
Offline mikerj
« Reply #14 on: April 10, 2021, 06:46:34 pm »
Boost converter usually.
Offline Jwillis
« Reply #15 on: April 10, 2021, 09:24:03 pm »
There are 6 individual LED strings . Although not impossible , it's unlikely all 6 strings failed at the same time .  The strings can be tested simply by providing 18V  in series with a resistor (1K should work) to the Drain of the MOSFET  then grounding each string at the Pins on P103 connector momentarily . It would only need to have one LED in a string for that string to fail .
For the sake of simplicity and to minimize confusion I will call it a LED driver because that is what the main component does .
Good thing the colour of the wire won't make the electrons flow in a different direction.
The transistor readings you gave look fine . They're not shorted or open .  MMBT4403L Data Sheet
I found a schematic for a Toshiba . It's not exact but gives a general idea of whats this driver does . The Schematic shows different voltages , values and has to 2 MOSFET's .
The green wire should go to high to turn on the OZ9967 . The exact value I can't say but if you attach a DMM to the green wire and turn on the display it should give a different value than when the display is turned off . If that works we can rule out that part of the control board .
Then check for a voltage change at any one of the bases of the 6 transistors . If there is a voltage change between the ON state and the OFF state then that part of the driver chip is OK .
Check the MOSFET    NIKOS P8008BD Data sheet
If that is fine we need to go back to the Brightness. If the Modulation to pin 23 is not working then the duty cycle to the LED's will be at the lowest power or dark screen .That would be an issue with the control board . If that is working then check the signal to the gate of the MOSFET . Difficult to do with just a DMM because it's PWM (Pulse Width Modulation) .Easier if you check for a current change if you know how with out shorting the MOSFET out .
Trace the yellow wire on the Driver Board and the Power board . I can't see where it goes in the photos
The Attachment below is for A Toshiba display but the concept is the same .
« Reply #16 on: April 15, 2021, 07:56:15 pm »
Hello,
Good thing the color of the wire won't make the electrons flow in a different direction.
You never know, the wave function could collapses differently in another part of reality. Thankfully it doesn't on our blue marble  ;D
Nice find for the schematics! I tried getting info from the manufacturer but they were quick in replying I didn't sign the NDA and asking were I got my chips.
So I have tested the ON signal using my DMM and Logic analyzer and there doesn't appear to be a signal. I used the red wire as ground (labeled GND on the connection going to the LED driver).
On the logic Analyzer I see no change, just a flat line all the way.
On the DMM I get 0V when the power is disconnected (a little higher actually but it drains to 0v after a few seconds), a steady 0.06v with power connected and when pressing the power button there is NO change.
So I guess I need to take a look at the control board? (That's the one with the video outputs right?)
I will start by probing around the cable coming from the power button assembly.
BTW thank you so much for your help navigating this!
« Last Edit: April 15, 2021, 08:06:12 pm by tcz »
« Reply #17 on: April 15, 2021, 08:16:56 pm »
Just tested for the ON signal on the wires coming from the control board (between the purple (on/off) and the green (GND) wires)
And I'm pretty much getting 0v all the way. I was expecting to get 0.06v but no.
Not being sure which GROUND I should be using (although what I know tells me all grounds should do) I measured again using other GND wires and the clearly labeled ground connection next to the power connection on the power supply.
Same results.
EDIT
I just found the signal for the power button on the ribbon cable going to the control board.
I attached an image showing the pinout.
When pressing the power button the blue pin gets shorted to the green pins which are both grounds on the control board. See image.
I'm now in the process of tracing the path of the "On" button signal to see were it goes, but there is a ton of tiny VIA in this area that makes things complicated.
« Last Edit: April 16, 2021, 03:51:15 am by tcz »
Offline Jwillis
« Reply #18 on: April 16, 2021, 04:49:47 am »
 Glad your progressing . Unfortunately your starting to get in the realm of digital chips. I can't even get a CD4013 flip-flop to work right .  :-DD
All I can say is try to get the data sheets for the chips on board . Maybe they can give some direction of what's gone wrong . There has to be a pin on one of them that is for back light power on .
Wish I could help more .
Offline perieanuo
« Reply #19 on: April 16, 2021, 07:03:01 am »
if sometimes you got background light  and no picture, then your problem is video signal path
no need to dig the LED driver for background light
green LED means the processor detected VGA signal. re-test connecting/disconnecting VGA cable or simply leave the PC in standby and move the mouse or shut dowa/start the PC, the LED should change state
IF it change state (the LED), that means processor board have at least some +5V voltage and detects VGA signal
normal repair means :
- verify voltages (at least with DMM)
- if voltages are OK and you got no scope, cut the apple in half by establishing if:
  - it's the backlight LED driver defective or
  - the LED background matrix
  - the control board (ON/OFF from start button works, VGA signal detection works, VGA signal is correctly processed --> MAKE SURE you display on that LCD some supported
    resolution/refresh rate, this is very important, you gotta setup output resolution of your device like a laptop first then connect your monitor, you can be out of monitor supported modes
    range
you are a little lost in this steps, so re-focus like i proposed and rething the approach to diagnose
this 'organigram' flow works for every monitor from 1980 to today
« Reply #20 on: April 16, 2021, 08:25:25 am »
You helped me a lot thank you. If I can be sure that the issue is the control board I can get a refurbished one for 26$, it may be worth it. Will look at schematics first if I can find it.
Thank you will do but FYI:
The power led is green even with no video cable connected.
It's not a computer resolution problem
I cannot get in the monitor's setup menu.
The ON/OFF from start button works but an ON signal never gets sent to the other boards.
Basically it wont turn on!  |O
While I'm here I will post an updated picture of my trace investigation and some close up.
« Last Edit: April 16, 2021, 08:48:41 am by tcz »
Offline perieanuo
« Reply #21 on: April 16, 2021, 09:46:35 am »
yep, more clear now
change the quartz or try reflowing or just press a little with your finger the proc and try on button then
i'm sure the proc gets on/off command, he's dead or stuck
if you're thorough in explaining what you did, we can diagnose, if you transmit half of your diagnose, we can't point the defect component
Offline Jwillis
« Reply #22 on: April 17, 2021, 10:05:01 am »
Not sure if this will help but I found a service manual for the LCD Monitor 2209WA  which uses the TSUMU58EHJ-LF-2 . Not sure how much difference there would be between the chip versions . They are both QFP-128 packages   https://www.manualslib.com/manual/794321/Dell-2209wa.html   free down load .
Anyway if you can trace the power on button to the chip it says that it should set the  pin low when button is pressed . That turns on the  TSUMU58EHJ-LF . Power pins are on page 27 not sure if they are the same . Doubt it but you never know .
According to the trouble shoot on page 47 if power to the chip is OK but no back light then the TSUMU58EHJ-LF needs to be changed which usually means changing the board .
Not sure if you can figure out which are the power pins .
Offline calzap
« Reply #23 on: April 17, 2021, 02:09:53 pm »
Hope you know that monitor can be bought refurbished with a warranty for about US$100 from NewEgg and others.    Now, if you want to work on it for fun and experience …  great!   Many times, I’ve spent hours fixing something where the parts alone cost more than a brand new one … learned and enjoyed, and very satisfying.
Mike in California
« Reply #24 on: April 20, 2021, 05:02:01 am »
@Jwillis  Thank you very much for the link to that service manual. I tried to set the pin low but it didn't work. BUT I'm going go through the rest of the manual as i'm sure there's a lot of similarity in how dell builds monitors.
@calzap  Yes I know :) I really want to learn how to fix this thing myself.
I'm also looking into the possibility of using one of those "universal LVDS" controllers but it's hard to get straight answers from Chinese sellers.
They do have some available on eBay for my panel (M240HW01 V1) but their picture show a kit with an inverter board for cathode back light instead of an LED driver.
