Author Topic: ESD in open board products like Arduino  (Read 612 times)
Offline praveenTopic starter
  • Country: in
« on: July 28, 2021, 11:34:59 am »
As a beginner Electronics student I hear a lot about ESD, safety, precautions and protection in the storage and assembly of the electronic components. Also I read that the damage caused by ESD is not apparent and the effects may take a while to realize.
I am wondering how Arduino, Raspberry Pi, STM32 boards, the shields and sensor modules that are sold as uncovered 'naked' PCBs with all the components exposed deal with ESD. Now obviously not everyone using an Arduino or RPi used it in an ESD safe zone, wearing wrist straps and stuff.
So how does it work? Are there measures taken to minimize (if not eliminate) ESD on a bare board?
Offline Siwastaja
Re: ESD in open board products like Arduino
« Reply #1 on: July 28, 2021, 11:45:30 am »
Having a full board with a lot of ground plane and ground pins exposed, the risk of getting a dangerously high ESD voltage at some IO pin or internal sensitive node is just so much smaller compared to if all the pins are exposed directly.
Also, for example, MOSFET gates are most sensitive to ESD, so they don't have those exposed on the board connectors.
IO pins that they directly bring out to pin headers have ESD protection, albeit not very good, but much better than nothing.
Finally, these products should really be handled with proper ESD precautions. It's just that given the above points, risks are smaller. If people have troubles with such cheap boards, they just say, "hey, it's broken", get a new one, and don't analyse why it failed. It can very realistically be due to ESD.
You could design said products to be safer against ESD, to different levels of requirements, but Raspi or especially Arduino do not do this because they are the lowest cost race to the bottom products.
You could easily add ESD protection components to each IO brought outside then add a tiny metal box around the product, but that could easily increase BOM cost by like +100% for an Arduino or like +20% for a Raspi.
« Last Edit: July 28, 2021, 11:47:32 am by Siwastaja »
The following users thanked this post: praveen
Offline Feynman
« Reply #2 on: July 31, 2021, 08:28:41 am »
Like you said, ESD most of the time occurs over time with a degradation of performance and/or life time. But since such boards are basically consumer toys, nobody expects these things to work for 10+ years within full specification.
The only reasonable way to eliminate ESD on a bare board is proper ESD safe handling.
