Not sure who makes it, could be Panasonic ZA series.
But it doesn't matter, it's a 100 uF 25v capacitor, polymer. (E says it's 25v)
You can probably use anything between 82uF and 150uF, the exact capacitance is probably not that important.
The voltage rating is important, should be 25v or higher because you probably charge with 18v..20v adapter, so voltage must be above that.
