Author Topic: Need Help Identifying Diode-looking Cmponent  (Read 547 times)
Offline groinksanTopic starter
« on: December 29, 2019, 01:34:41 am »
I came across a bunch of these NOS components. It looks like a diode, however there is no labeling on the component. Photo is taken with a digital microscope. On the bag, it is hand-written "CAT # 92CU 1871" and "AMT. 5,1V"
Offline bob91343
Re: Need Help Identifying Diode-looking Cmponent
« Reply #1 on: December 29, 2019, 03:00:21 am »
My guess is a 5.1 Volt zener diode.
The following users thanked this post: groinksan
Offline googlyone
« Reply #2 on: December 29, 2019, 03:01:52 am »
Initial comments:
- There is something really funky going on with the plating on the leads.  It seems to be scaling off, which is not a happy thing.
- If I were to guess, the 1871 has a "fair" chance of being a date code, week 18 of 1971
- any "diode like thing" with "5.1V" associated with it make me think of a zener diode
- Just to make the above confusing, an old glass enevlope diode with "...92" written on it makes me think OA92, a very common germanium diode.
Obviously the last two clues are quite contradictory - so at least one and likely both of the above clues are wrong!
The only sensible advice from here is to test its forward and reverse breakdown.
- Take a power supply (say 15V - or a 9V battery if you have one laying around).
- Measure the voltage of the power supply / battery using your DVM
- Put a resistor in series with the positive lead.  (any value from say 1K to 100K will do - 10K is ideal).  This acts as a current limit.
- Connect the diode from the power supply negative to the open end of the current limiting resistor.
- Measure the voltage across the diode using a DVM
- Try this with the diode "forwards" and "backwards".
If you get:
- The full supply voltage one way, and 0.6V +/- 0.1V the other way you have a silicon diode
- The full supply voltage one way, and 0.3V +/- 0.15V the other way you have a germanium diode
- 5.1V +/- 1V one way and a low voltage the otehr way you have a 5.1V zener
Else I have no idea what you have.
Bottom line though: Any component with skanky plating like that is likely to give you grief in use.  Diodes are super cheap.  With the possible exception of some really old germanium devices - but even then I am not convinced I would want to use them.
