Author Topic: Need help identifying fried chip.  (Read 1175 times)
Offline RosePeachTopic starter
« on: October 11, 2019, 02:46:38 am »
I recently was powering my Akai MPK Mini mkII midi keyboard from an Arduino USB Host shield and anciently supplied to high a voltage and fried a chip inside the keyboard. I would greatly appreciate it if someone could help me identify the chip so I can order a replacement from DigiKey to repair my keyboard. I have included pictures of the carnage as attachments. I believe the chip has markings that say "62 2".
Thank you,
Rose Peach
« Last Edit: October 11, 2019, 02:48:16 am by RosePeach »
Online ataradov
    • Personal site
Re: Need help identifying fried chip.
« Reply #1 on: October 11, 2019, 03:18:06 am »
This is a TVS diode array. Given the nature of the failure, remove it and see if the reset of the board still works. It is not essential to functionality, it is only there for protection. And it did its job. But it is possible that something else got damaged too.
Alex
The following users thanked this post: RosePeach
Offline LateLesley
  • Country: scotland
« Reply #2 on: October 11, 2019, 09:20:48 am »
I agree with ataradov, it looks like diode protection, and the package is marked with a "D1" which is standard for diodes.
I think you have something similar to this - http://www.ti.com/lit/ds/symlink/sn65220.pdf
It's not the same package markings, but I think it's the same pinout.
« Reply #3 on: October 11, 2019, 01:40:20 pm »
Thank you so much for your help. Could you help identify which package type the chip is? I'm not too familiar with the different names.852446-0
Online ataradov
    • Personal site
« Reply #4 on: October 11, 2019, 03:48:33 pm »
This is SOT-23-6. But again, test the rest of the board before ordering the parts. If it does not work without them removed, it will not help putting them on.
Alex
Online wraper
  • Country: lv
« Reply #5 on: October 11, 2019, 03:59:53 pm »
This seem to be dual channel type with lines going through it. So it's unlikely device will work after simply removing it. You would need connect together pins 1-3 and 4-6. Also it seems as if it shorted 5V to GND through itself.
« Last Edit: October 11, 2019, 04:04:35 pm by wraper »
Online ataradov
    • Personal site
« Reply #6 on: October 11, 2019, 04:03:09 pm »
This seem to be dual type with lines going through it. So it's unlikely device will work after simply removing it.
Yes, after a closer looks at the layout, I agree.
Still temporarily bypassing the device for a test might be a good idea.
Or got way more than 5 V on the power lines.
Alex
