2 questions... (1/2 a repost from another thread...but...ya know...)
1)
For my ASA project, I've settled on an ADG1406 16 channel analog MUX....I think. Want to run it by anybody that is probably more in the know than me...or cares for that matter
This is for the curve tracer project I'm playing around with. Need to switch a select resistor into the D.U.T. part of the circuit. I was going to use a bank of relays. A-takes up too much room, B-don't want to listen to the relays clicking.
The signal going into any of the inputs will run anywhere from 100mV to ~12v pk-pk, AC sine wave, roughly 20hz up to 100khz at most. Resistors to be switched will run anywhere from 10ohms up to ~100k. At the higher pk-pk input voltage settings, the lower value resistors will be 'locked out' so the chip doesn't get overloaded with too much current.
28 pin TSSOP, dual supply @ +15v/-15v (I'll be running it at +12/-12 at most), fairly low Ron at the switches, low enough for my app.
Page 7 of the datasheet (
http://www.analog.com/static/imported-files/data_sheets/ADG1406_1407.pdf) shows it'll do 180mA per channel continuous, which is about double what I'll be feeding it, and even then, I'll be feeding a sine wave thru it, so shouldn't be hitting anywhere near the max current limit for any length of time.
2)
On the subject of those AD9850 DDS modules from ebay. I'm going to assume I don't get one that counterfeit or otherwise "faulty"...
Google'ing the subject shows a lot of HAMs using these to generate high freq's (e.g. >1Mhz). I'm looking to use one of these modules down near the audio range (e.g. 20-20k).
Is the output from these modules pretty clean at low freq's as well?
