I am in need of help in identifying two FPC connectors (plugs). Also, I need their mate (receptacle), but it should be easy knowing the plug.
Provided are photos of the connectors with some dimensions taken. Photos of the plugs are taken by me. I do not have a receptacle to take a photo, but found some photos online (it was listed as used salvaged part, and no part number was given).
Note, that the corner contacts on the big connector are partially covered with plastic.
If it helps, the connectors are for Blackberry Z10 LCD (big), Touch (small), and LED Backlight (same small). Schematics for the device are available, but use internal part numbers throughout (CON-00800-001 for the big one, and CON-00737-001 for the small one).
I tried Mouser, Digikey, and Octopart's parametric search, but could not find anything similar.
Imgur album with photos (too big to attach to post):
https://imgur.com/a/p4XbWVu
