And because hfe varies widely with temperature, age, voltage, between identical transistors from the same batch and by phase of the moon, you'll want to half the resistor value calculated by the maths for reliable operation.
Or, if the datasheet specifies a range of hfe, use the lower number to calculate the base resistor the reduce it further by 20%.
