Our initial design was using the TPS560430 chip as a step-down converted from a Vin of (12-16V) down to 3V3 with the 3V3 rail looking like this (Vpp is 120mV, sorry for the quality):
Because of the chip shortage, we were forced to replace the TPS chip with the NCV3063DR2G and the following design:
Unfortunately the 3V3 rail is looking much worse, badly affecting the readings of one of the sensors:
I can see in the PSU's chip datasheet that the recommended capacitor on the output is 470uF for 800mA of current. Our design barely goes above 20mA, so the thinking here was that the 150uF should be enough. Is there any way evading this problem? Here's what we've tried so far:
Replacing the 150uF electrolytic capacitor with 3x 47uF ceramic caps stacked onto each other as a test. The performance seems to have improved, although it's still worse than before.
Have ordered 220uF ceramic capacitors for the output which should hopefully make things a bit better.
Is there any other more obvious solution? Neither of us is an expert in PSU design, so we might be missing something really obvious and simple here.
Thank you!
