Author Topic: Problem with Wall adapters  (Read 3877 times)
Offline ElectroElvisTopic starter
  • Country: at
  • http://electroelvis.com/
    • ElectroElvisBlog
« on: November 01, 2012, 10:16:47 pm »
Hello all,
I know I havent been around lately but once again I need little help.
Currently I am working on to little project with small portable amplifiers and I have problems connecting evrything to wall adapter via 5V or 12V voltage regulator. I have 3 Wall adaptors:
1. Trust 12V 500mA
2. Hitron 15V 800mA
3. Netgear 12V 1A
When I test adaptor 1 and 2 I am reading only max 2V without being or with being connected to somthing.
Only Netgear's adaptor works but since it is too powerfull it is not any good use for me.
Is there something that I am missing with adaptor 1 and 2? I know that both worked normaly before powering their gadgets.
Elvis
Online IanB
Re: Problem with Wall adapters
« Reply #1 on: November 01, 2012, 10:33:09 pm »
What is your concern here? Your household mains outlets can supply something like 15 A. Does this mean they are too powerful to run a cellphone charger that only needs 0.1 A?
  • Country: at
    • ElectroElvisBlog
« Reply #2 on: November 01, 2012, 10:52:59 pm »
I want to know why other two doesn't work, since I cannot open them due to safety build. And to answer question: To step down input I would need to transform it to heat which I dont need and specially no aditional parts:)
Thank you for your reply,
Elvis
Offline Monkeh
« Reply #3 on: November 01, 2012, 11:00:16 pm »
Elvis
It's the same voltage as #1 and lower than #2, what's the problem?
Offline Psi
« Reply #4 on: November 02, 2012, 01:31:13 am »
Are you sure all the adapters are DC
If the first two are AC you might see ~2V on a DC meter
Offline ptricks
« Reply #5 on: November 02, 2012, 11:38:31 am »
Too much current isn't an issue as long as the voltage is the same.
 Some devices expect a  load before they start delivering power, usually these are switch mode supplies. Also true for power supplies used on things like laptops, cell phones where the adapters are 'smart' and will cut the power if they detect something not right.
Offline Chryseus
    • My Website
« Reply #6 on: November 02, 2012, 02:15:24 pm »
2 and 3 are exactly the same power (12VA) so I don't know what you mean by too powerful.
If 1 and 2 are switchmode (you should be able to tell by weight / size and input rating) what ptricks is saying is correct and you need a minimum load.
You might also want to read the label to make sure they output DC not AC.
« Last Edit: November 02, 2012, 02:17:37 pm by Chryseus »
Offline Jon Chandler
    • Throw Away PIC
« Reply #7 on: November 02, 2012, 04:26:33 pm »
Here's a pretty good reference if I do say so myself: AC-DC Power Supplies - Using Wall Warts
The first consideration is what type of wall wart it is.  There are three general possibilities:
1.  It's a step-down transformer with an AC output.
2.  It's a transformer-based linear DC supply.  The important thing to know about most of these is that there is no voltage regulator in the device.  At the rated load, the voltage will be close to the nameplate, but at a light load, the voltage can be significantly higher.
3.  It's a regulated switching power supply.  This is the usual case for cell phone chargers and many current-generation supplies for electronics devices.  These will supply a constant voltage over the supply range; sometimes a minimum load is required for operation.
A fourth possibility is beganing to appear, the constant-current switching supply for driving LEDs.  If the rating is something like this, it's a constant-current supply:
OUTPUT
300 mA
1.2 - 7.4 V
The third type is the most useful for powering projects.
Once the type of supply is known, the second issue is the supply rating.  Suppose we need a supply for a microcontroller board that doesn't have its own regulator.  It's a 5 volt system, so we'll need a 5 volt supply.  That part is easy.
But what current rating do we need?  Electronics circuits draw only the current that they NEED.  A supply must be rated to provide AT LEAST this much current, but a larger rating won't cause the board to draw more current.
Back to the microcontroller board.  Lets say it has 8 LEDs that could draw 10 mA each, a PIC18F-series micro, and not much else on the board.  The LEDs are the biggest current draw, 80 mA if they're all on.  A power budget of 100 mA is about right.  So a supply rated at 5v at 100 mA or greater will do the job.  Operation and current draw will be the same whether the supply is rated for 100 mA, 500 mA or even 2000 mA.
Do verify polarity of wall warts before using!  Red is not always positive and black is not always negative.
  • Country: at
    • ElectroElvisBlog
« Reply #8 on: November 02, 2012, 07:25:10 pm »
OUTPUT
300 mA
1.2 - 7.4 V
Thank you very much my friend for lovely explanation of what I have asked.
Elvis
    • Throw Away PIC
« Reply #9 on: November 03, 2012, 05:45:05 am »
Elvis
From this response, I'm not sure if my post was of any help to the original poster...
One detail I did not mention but which is in the linked article is how to tell the first two types of supplies from a regulated switcher.  For either of the first two, remember that the largest component will be a heavy transformer, and the transformer shape is approximately a cube with equal-length sides.  The enclosure must include some room for the rectifiers and filter caps (if it's a DC supply) but the package is approximately an even-sided cube.
On the other hand, switching supplies aren't limited by the need for a large, heavy transformer.  These supplies tend to be more compact, not a cube shape and put out much more current for the size.
So, if a supply is roughly cube-shaped and heavy considering the output current, it's probably got a transformer.  So how can you tell if it's an AC(just transformer) or linear DC supply?  Perhaps measuring AC and DC output voltages will provide a clue!
