Was wanting to make a sort of all purpose supply cheep for use in the shop. Small motors lights gadgets. Battery powered drills are almost discarded by people because when the battery packs that are more $ than the drill no longer take a charge they are practically given away. I have about 4 that I have found for less than 5$. And have gotten one to run great off of a laptop power supply. But have it permanently wired into the gutted battery pack. And it's output is to high for smaller jobs. So the ATX with switchable volts is kinda ideal for the task I do. If I could just get them to work on all the different volt settings. The "wimpy one" I built would be ok for other things if the 5v and 12v wouldn't shut the device off? Even a small 12v light will kill it? A 12v RC car motor shuts it off. So would a 600w ATX perform those task ?
If this is what you want, then a
modern ATX supply with a sufficiently powerful 12V rail (15-20A or more rated) could do the job. However, most battery powered drills need more than 12V (14-19V being typical) and there is not really a good way to get that out of an ATX supply cheaply and safely, especially with your level of experience. The drill may run at 12V, but it will very likely lack power to the point of being unusable. Only the smallest cordless screwdrivers run at voltages lower than 10V or so.
If you post the ratings of your drills, then some more specific advice could be given - e.g. an industrial power supply with a fixed voltage and sufficient power rating could be an option. Then have a second adjustable supply for your low power things.
However, without knowing more about the type of drills or motors you want to power it is shooting in the dark. "Battery drill" or an "RC motor" is too vague - RC motor could be a small DC servo taking milliamps of current but also a large brushless motor drawing 100+ amperes ...
How about this. ? Could I build a box with a bunch of wall warts wired in a parallel on the input side
A wall wart is
extremely unlikely to have sufficient power to run a drill. You will most likely fry the wall wart if you try it, especially if you have bought some cheap junk ones without much of an output protection.
