I have a PCB that I was about to assemble. In fact, I've already soldered one part onto it (the AT Mega 128L). I was just curious and decided to check what the resistance was between my 1.8V rail and ground and I found an interesting result.
My meter gives me a reading in the mega ohms range. It varies between 0.5M to 40M and it doesn't really stabilize. These tracks are unconnected at this stage. The MCU is only connected to 3.3V and GND and the 1.8V rail does not come near it. I would have expected the 3.3V to Gnd resistance to be in kOhms range and the resistance between 1.8V to GND to be pretty much infinite. The 3.3V to Gnd resistance is as expected in kOhms but the other result is bewildering.
Some (but not all. Most give 0L as the meter isn't able to measure it) other tracks also give me this reading. I'm not sure what to think. I don't have another PCB on which I could test this on but from my limited knowledge, I feel that isn't this entirely normal and could cause my circuit to fail.
Any advice regarding this would be appreciated. Here's a link to my PCB:
Apologies for the not-so-good layout. It was really only my 3rd or 4th one and the most complicated that I've done. I measured the resistance between 1.8V rail and GND at P1 and the pads at C103 and C102 - all unconnected as I mentioned. The PCB is unassembled with the exception of U3 (Mega 128L).
