Hi, im looking at some old splitflaps in order to put them to use again.
So basically they work as a kind of stepper motor, they operate on 24V 150mA current (160 Ohm coil resistance) for about 50ms in one or the other direction to flip to the next character.
As you can see in the pictures, all these devices have capacitors soldered directly across the coil inputs, i've not been able to decode the colors to anything sensible, I measured 4 of those and 3 measured about 4nF and one about 100nF.
I know capacitors are used across dc motors to filter the noise from the brushes sparking and such, but what would be their function in a stepper motor like this without brushes? any ideas?
