Author Topic: Need help with resistor network from hell  (Read 5029 times)
Offline modalenjrTopic starter
  • Country: no
« on: November 19, 2015, 11:26:40 pm »
Does anyone have a math formula to solve this one? (see attachment)
Offline fivefish
Re: Need help with resistor network from hell
« Reply #1 on: November 19, 2015, 11:31:07 pm »
R4 || R2 || R5 are in parallel. Compute equiv. resistance of these 3 parallel resistors, let's call it R2'.
1/R2' = 1/R2 + 1/R4 + 1/R5 .... solve for R2'
Then do R1 + R2' + R3
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: November 19, 2015, 11:31:43 pm »
23.3... kohm
Spot the resistors in parallel and use the parallel formula:
1/Req = 1/R1 + 1/R2 + ... + 1/Rn
Then spot the resistors in series and use the addition formula:
Req = R1 + R2 + ... + Rn
Seven Transistor Labs, LLC
  • Country: no
« Reply #3 on: November 19, 2015, 11:43:01 pm »
Sorry i draw it wrong |O
Online Andy Watson
« Reply #4 on: November 19, 2015, 11:50:55 pm »
Easy! Remove R2. Work-out the resulting network.
Now put R2 back ... if you want - it makes no difference.
  • Country: no
« Reply #5 on: November 19, 2015, 11:56:34 pm »
Don't mind 10K, Every resistor can have a different value.
Online wraper
  • Country: lv
« Reply #6 on: November 20, 2015, 12:02:18 am »
For easier understanding the same thing drawn differently:
« Last Edit: November 20, 2015, 12:06:15 am by wraper »
Offline helius
« Reply #7 on: November 20, 2015, 12:03:51 am »
In this case the key is that both sides of R2 are equipotential nodes. So no current will ever flow through R2.
It's clearer if drawn this way:
     /--R1--+--R4--\
>----+      R2      +---->
     \__R5__+__R3__/
Online Andy Watson
« Reply #8 on: November 20, 2015, 12:16:16 am »
You didn't mention that!
In that case: Label the ends of R2 as points A and B. Split the network at A and B such that R1, R2 and R5 form an isolated network. Use a delta-star transform on R1, R2 and R5. Now reconnect the star-network to the points A and B.
Online T3sl4co1l
« Reply #9 on: November 20, 2015, 02:00:10 am »
For reducing circuits of this shape, you need nodal analysis (the sledge hammer), or if you prefer a graphical approach, apply delta-wye transformations as mentioned by
Application of this will lead to equations with a lot of R / (R1 + R2 + R3), which after putting things together, probably looks a lot like what blueskull has. :) (I don't particularly care to check the result for correctness.. :-DD )
« Last Edit: November 20, 2015, 02:02:06 am by T3sl4co1l »
Offline Syntax_Error
« Reply #10 on: November 20, 2015, 03:03:24 am »
Dave will have a video on nodal analysis, mesh analysis and superposition theorem soon.
In the meantime, you can look at the lectures here:
http://www.digilentinc.com/Classroom/RealAnalog/
Click show all and watch chapter 3 videos and the first video from chapter 4.
It's perfectly acceptable to not know something in the short term. To continue to not know over the long term is just laziness.
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #11 on: November 20, 2015, 12:28:14 pm »
You can use y-delta tramsform. Use this to turn r1,r2 and r5 intoa y.
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline Electric flower
  • Country: hr
« Reply #12 on: November 20, 2015, 09:02:36 pm »
On first picture you see how to transform delta configuration of resistors into star (or Y)
NOTE: If you had ditched R2 you would still get same result of 20Kohm beacuse all resistors are of the same value, but if they were different you would have to use delta to Y transformation
Side question, if picture is worth thousand words, how much is worth picture of words?
Edit: On the second picture where is correctet exponent on 100 should be 100*10^6, not 100*^5
« Last Edit: November 20, 2015, 09:07:28 pm by Electric flower »
All work and no play makes Jack a dull boy.
All play and no work makes Jack a mere toy.
