Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Combining bridge rectifier outputs for higher combined Voltage
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Combining bridge rectifier outputs for higher combined Voltage (Read 1519 times)
SkrillBill
Regular Contributor
Country:
on:
November 24, 2017, 03:52:00 pm »
Working on designing a very basic powersupply (4 outputs; 3 fixed 1 variable) out of some voltage regulators.
Supply will be 1Primary/2Secondary transformer. 115-120v@60hz/ 16v on each secondary. Secondaries are each fed into a rectifier. One rectifier will feed the 5 and 12v regulators, but i need the combined output for the 24 and variable. What is the proper way to tie the outputs of the rectifiers together? Here is the schematic (digikey scheme-it):
https://www.digikey.com/schemeit/project/powersupply-v1-1-GDI647G303I0/
Thank you
Logged
trys
Regular Contributor
Country:
I started with the AC128
Re: Combining bridge rectifier outputs for higher combined Voltage
Reply #1 on:
November 24, 2017, 05:00:37 pm »
Duplicate post:
https://www.eevblog.com/forum/beginners/4-output-(but-very-basic)-power-supply/
Logged
Simon
Global Moderator
Country:
Did that just blow up? No? might work after all !!
Reply #2 on:
November 24, 2017, 05:02:56 pm »
Please don't post the same question multiple times, it's poor etiquette.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
