Author Topic: Need help with TTL only termometer and voltmeter and 7 segments display  (Read 721 times)
Offline little_carlos
Hi, i need to make a voltmeter and a termometer using TTL only chips, and display the info on 7 segment displays, can you tell me which IC's should I use?
Offline danadak
What are the voltmeter and thermometer chips  you are going to use ?
Regards, Dana.
Regards, Dana.
hi, the voltmeter is just a crappy adc reading from 0 to 5V and display the result on a 7 segment display
the thermometer is a lm35, since accuracy is not required
