Hello, I'm currently doing my technician. I have a question about the following task.
"What minimum sampling frequency must a DSO have in order to be able to measure the fall time in the pulse voltage shown in Fig. 1.1 up to the 9th harmonic using dot reproduction, vector interpolation and sine interpolation?"
The frequenz of this pulse is not essential, i will understand the theory behind this.
I know the Nyquist theorem, which says: bandwidth > f*2
So far so good. I bought the solution to this task online because I want to check my solution afterwards to get my grade.
Unfortunately, I couldn't find anything when I searched online and in my study documents as well
I want to understand the topic and not simply write it off.
The solution to the task was as follows:
Bandwidth for sine interpolation (si(x)) = f*2.5 (Nyquist okay)
but for the bandwidth
Vector interpolation = f *10
and for dot reproduction = f*25
I wonder where the other two factors come from and why I can't just use one factor for all 3 functions?
And why exactly these factors? And not, for example, *30 or *50. Is there any practical experience here?
Thank you for help
