You don't say what kind of bandwidth or slew rate you need. RRIO op amps tend to compromise in these areas for ease of use. The TLV172 for example drops to 0.3MHz GBWP within 2V of its positive rail, with equally poor slew rates, but otherwise is RRIO with no latching or phase inversion effects. If you're sampling very low bandwidth signals, such as a temperature sensor or a fuel gauge, then this is no problem. So it really depends on what your application is.
