It looks like there is a type number lasered between the lens and the pins.Maybe you can read it when you change lighting conditions.
It seems there are different receivers with different pinout: https://microcontrollerslab.com/tsop1738-ir-receiver-pinout-examples-arduino-applications/ . Look how similar devices have mirrored pinouts.For example, this module looks like yours: https://www.aliexpress.com/item/33001722129.html . It's hard to see traces, but possible. Look where GND is located.So, may be there are different receivers on the market that look similar?
Quote from: exe on December 05, 2020, 11:25:16 amIt seems there are different receivers with different pinout: https://microcontrollerslab.com/tsop1738-ir-receiver-pinout-examples-arduino-applications/ . Look how similar devices have mirrored pinouts.For example, this module looks like yours: https://www.aliexpress.com/item/33001722129.html . It's hard to see traces, but possible. Look where GND is located.So, may be there are different receivers on the market that look similar?In principle, everything is possible. How many receivers do you have, only one? I buy at least two ICs as I tend to burn them due to wrong wiring all the time .PS if your power supply can limit current, I suggest test at minimal current, although this doesn't guarantee that ICs will survive abuse (also, even a short overload may change their chracteristics).Thanks for the links and I connected the one I have like the one in the 1st link, with GND on the left as you look at the front of the TSOP1738. But it could be that the GND is on the right??
