Autodetect is only for parallel eproms. It can destroy all other ICs. BTW this should be M93C86WP made by ST, not ST93C86WP. I cannot find the datasheet from ST but here is from Catalyst. According to it, W might mean different order of pins. Check the actual PCB for what pinout variant power pins do match. If there is no M93C86W (or J) or CAT93C86W(J) or any
93(C or whatever)86W(J) in the IC selection list, then you can just make an adapter on the breadboard or just with wires, or whatever to match the pinout commonly used for 93C86.
