Author Topic: Providing clock to micro: crystal vs oscillator  (Read 3073 times)
Offline MoriambarTopic starter
Re: Providing clock to micro: crystal vs oscillator
« Reply #25 on: May 27, 2021, 02:07:15 pm »
Did you find the documens linked below?
https://www.ti.com/lit/pdf/swra372&usg=AOvVaw07hrK5qhcqPR5RBU0xUJp7
http://ww1.microchip.com/downloads/en/appnotes/00826a.pdf
If you want to be pedantic about getting the right value, it's possible to calculated it.
The MCU input pin and parasitic crystal capacitances can be found on the data sheets. It's also possible to calculate the parrasitic, but as mentioned above, an approximate value is good enough for most applications.
no I did not find those, well not in the first results... thanks for the links.
Anyhow now I have a better grasp of the whole matter, thanks!
