Author Topic: Probe issulation to my scope - DIY / buy?  (Read 8542 times)
Offline f1r31c3r
  • If you trying, you ain't
    • f1r31c3r
Re: Probe issulation to my scope - DIY / buy?
« Reply #25 on: May 27, 2021, 06:34:29 pm »
I know this is an old post however i thought maybe someone searching through the forum or coming across this post may want this design from an article in the CircuitCeller magazine.
https://circuitcellar.com/research-design-hub/high-voltage-differential-probe/
The circuit above with the placements of the capacitors blocks DC and you may want to measure DC but have a high resistance to reduce the current to a safe level as not to damage the scope. This is why a set of series resistors are used, mainly so that if one of the resistors fail the rest wired in series still provide enough resistance to reduce the current to the scopes front end.
Hope this helps someone out.
I i have an Oscilloscope and you take it, what do you have?
A broken nose and no oscilloscope is what you have.
The following users thanked this post: icpart
