Author Topic: Neon lamp on analogic scope trigger pcb  (Read 1605 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
« on: April 14, 2019, 08:18:57 pm »
What are these neon lamps for when placed on a trigger board of an analog scope?
Offline alsetalokin4017
Re: Neon lamp on analogic scope trigger pcb
« Reply #1 on: April 14, 2019, 08:26:27 pm »
voltage regulation
The following users thanked this post: gkmaia
Online tggzzz
« Reply #2 on: April 14, 2019, 08:47:48 pm »
Show us the complete diagram, especially whatever the neons re connected to via P402.
Offline Cliff Matthews
    • General Repair and Support
« Reply #3 on: April 15, 2019, 12:19:15 am »
OP may find help here: https://www.eevblog.com/forum/testgear/tektronix-2246-no-beam!/msg314786/#msg314786
(Tek's 2246 uses this limiter too)
« Reply #4 on: April 15, 2019, 02:03:21 am »
There you go!
« Reply #5 on: April 15, 2019, 02:18:18 am »
Same idea, maybe they copied Tek limiting that grid to ~130v. A lot more than just triggering going on there IMO.
Offline floobydust
« Reply #6 on: April 15, 2019, 02:39:23 am »
The two series-connected neon lamps form a gas discharge tube protecting the CRT and driver from any static or arc discharges.
They go directly across the cathode-to-control grid of the CRT. Nothing to do with the trigger section. The two clamp diodes D407, D408 prevent any +ve CRT grid bias and the neons limit -ve grid bias to ~180VDC.
They should never be glowing except for maybe a blip on power up/down.
« Reply #7 on: April 15, 2019, 03:29:21 am »
Thanks for all the answers.
What is right way to test these lamps and make sure they are in working condition?
Offline tautech
« Reply #8 on: April 15, 2019, 04:31:54 am »
They rarely are crook as they're only ON in an over-voltage event (read fault).
Typically neons conduct ~90V.
Online tggzzz
« Reply #9 on: April 15, 2019, 06:59:11 am »
There you go!
That's more complete information, especially the scope type - other people might have specific experience of a particular scope type.
That isn't the case here, but we can see the neons are a traditional way to protect the tube from excessive grid-cathode voltages. In functioning Tektronix scopes they flicker on/off for up to 10s after the power has been turned off.
