Just a quick update. I ordered the slotted phillips #1 and the slotted pozi #1. I filed them both down to fit the screws better. The slotted pozi worked best, but the klein I was using originally was a very close second. I think as of now there is really no perfect screwdriver for these terminal screws and if you look really closely at them I think they were actually designed to cause a screw driver to slip, maybe to prevent over tightening. Even the part of the screw that is a flathead doesn't have walls that are 90 degrees. There is a slight angle to them like this \_/ and it causes the flat head to slip after a certain amount of torque. In short, these screws are just total garbage and I think I made a little progress, but mostly I just have to accept the fact that they are garbage.
