All of my Flukes do this. Try shorting the leads together. If it drops to 0.00 immediately, you have nothing to worry about. It's just stray inductance from the environment. I think cheaper meters are either just not sensitive to pick up EMI, or they use some sort of "zero-ing" circuit to discourage the behavior since a regular Joe would probably think it means the meter is broken.
