Folks,
Making my first post on the forum so do let me know if I've placed it in the wrong place. I'm a retired Real Time / Asynchronous Software Engineer (DEC PDP, VAX and various PC based systems running Unix, Linux, MS Windows etc.) that worked a good portion of my 'Glory Years' with a company that also developed Hardware so I had the chance to explore a bit with TTL and CMOS circuit design as a hobby.
I left the hobby around 1995 but by then had gone the Radio Shack / Forrest M. Mims III route, and with grand advice from the hardware development folks I worked with, have etched some PCBs of simplistic design and produced more than a few breadboard IC projects that did neat things like voice recording / playback and such. Those experiments were all Low Voltage (5V ~ 12V) DC powered stuff and did not include AC usage.
So, retirement is here and with a ton of different components still on hand, several breadboards, a multimeter / passive component tester and a logic probe I decided to get into things again.
While researching some stuff I ran across Oscilloscopes, found EEVBlog and David's excellent videos on them, and ultimately wound up sourcing a Rigol DS1054Z, Rigol's DK-DS6000 Demo Board, a Velleman O-Scope Tutor Board and a couple of books (Heeres' 'Oscilloscopes: A Manual for Students, Engineers, and Scientists' and the ARRL's 'Oscilloscopes for Radio Amateurs').
SO, I'm currently knee deep in reading and learning about the scope (and scopes in general) and how NOT to blow anything up. I have watched David's #279 video several times and am being very cautious! After WWII my Dad got into TV / Radio repair for several years before changing careers and had experience on scopes of that time (50's ~ 60's) but none of that translated to me as he was out of that line of work by the time I hit elementary school. I can't help but think how much he would FREAK over the low cost and capabilities of the basic Rigol scope I just bought! :-)
Enough about me and on to my (hopefully not too ridiculous) question. It started with a reference to 'Generating Lissajous Patterns'. I saw I needed two waveforms of the same Amplitude and Frequency but of different Phases. I have several waveform signal sources but none give me Phase adjustment options so I thought breadboarding something might be an option.
Then I thought about probing two (or more) separately powered boards via separate Channels (with all involved boards producing the same basic signal but one with one Phase, and the other(s) with different Phases). That brought up questions of the Power Supplies for the boards being separate, possibly at different levels and possibly of different types (AC vs DC vs +/- Split DC). Yikes! Am I headed down a wrong (and possibly dangerous - to the boards, scope AND Me) path with that idea?
David's #279 video makes it exceptionally clear that all 4 Channels and USB Cable on the scope share a common, Earth Referenced Ground with each Probe's Alligator Clips and it is here where I begin to wonder about connecting those grounds to boards with differing level power supplies that may be either isolated or Earth Referenced. Add in AC vs DC vs +/- Split DC and I'm definitely back to YIKES again. I think I need to better understand the subject of Potential and how that works.
I've attached a diagram that may more clearly depict the possible combinations I've alluded to above (but lacking the +/- Split DC example), one that uses specific examples of the items I currently have. Any advice on this would be much appreciated as I'm just not far enough along in my education on this to understand the ramifications of the various combinations being simultaneously connected to the same scope via different Channels that share a common, Earth Referenced Ground.
Back to the 'Generating LissaJous Patterns' desire that got me on to this subject in the first place. What I may well be looking for is a single dual-output circuit that produces two signals of common Amplitude and Frequency where one signal output is fixed and a second signal output is Phase adjustable with both signal outputs being powered by the same Isolated DC supply, but the question of using multiple boards with differing level power supplies and types (AC, DC, +/- Split DC) to do the same remains for me.
Barry
