Hello,
I have manged to fix the problem using two batteries in series to obtain the V+ and the V- for the opamp.
Firstly, I tried using two 9 V batteries in series (picture, ' 2x9V') - I took the middle point between the batteries as ground, then the positive of the first battery (left, picture) for V+ (9 V) and the negative of the second battery for V- (-9 V). This now though seemed to give me a persistant -7 V on the output of my opamp-buffer.
The next thing I tried was to swap the 2nd 9 V battery with a 1.5 V battery (picture, 'V- at -1.5V'), again taking the point the two batteries as ground. Now I get a persistent 400 mV on the output, not the original 1.9 V I had when I had V- tied to ground. This kind of makes sense to me because, when V- equals ground, Vout = 1.9 V, and when V- = -1.5 V, Vout = 400 mV - 1.9 V - 1.5 V = 400 mV.
Essentially, what I have learnt from this is that, if I have a unwanted voltage offset on my buffer opamp, what I can do to eliminate this (in theory) is to add the negative of this offset (in volts) to the opamp's source voltage, e.g. if i have Vout offset of 1.5 V, I can just add -1.5 V to V- to get a Vout of 0 V, or, if I have an Vout offset of -1.5 V, just add 1.5 V to V+.
Is this correct?
Thanks,
