As a side note.If your pack isn't charging it's likely a bad cell.It only takes one cell to be a little off for the management circuit to disable the whole pack. This is a safety thing incorporated in all lipo battery packs to prevent possible explosion or fire caused by bad cells. Although new cells can be installed and the management system can be reset its often more economical to just replace the pack.
