Author Topic: This amplifier gives incorrect V_OUT for small VIN difference  (Read 2290 times)
Offline king.osloTopic starter
  • Country: no
Hello there,
I've tried to simulate this with all sorts of precision amplifiers, and now I need some help, because I've failed.
I have a small voltage difference between non inverting and inverting input of 1mV. But still I get 40mV from the output. The amplifiers I've used, typically have some uV input offset, and low input bias currents.
Attached is my circuit.
Thanks.M
Offline 6502nop
  • $EA
Re: This amplifier gives incorrect V_OUT for small VIN difference
« Reply #1 on: July 27, 2012, 04:32:14 pm »
In other words, check your Vref (pin 5 of the LT1991) to make sure it's at the zero point (0V if using a dual supply, 1/2 Vcc if using a single supply). The example shown on page 1 of the datasheet shows it at 2.5V on a single 5V supply. Your schematic shows the end of the 450K @ pin 5 is grounded, but the negative rail is also at that point, so... Vee=Gnd?
nop
  • Country: no
« Reply #2 on: July 27, 2012, 04:55:19 pm »
It works if I add a dual supply, but at ref = 1/2VCC, I have no luck. Why not?
Thanks.M
Offline PA0PBZ
« Reply #3 on: July 27, 2012, 05:23:31 pm »
At 1/2 VCC your output will also be at 1/2 VCC when your inputs are equal.
It's not right there because your 1K resistor is too small, change that to 10K and you will see.
« Last Edit: July 27, 2012, 05:26:27 pm by PA0PBZ »
  • Country: no
« Reply #4 on: July 27, 2012, 08:31:35 pm »
Thanks. That worked fine :) M
