Author Topic: New tool or not  (Read 2114 times)
Offline Hornnumb2Topic starter
New tool or not
« on: January 14, 2019, 09:12:37 pm »
I have a hakko fm-206 that has the pencil hot air, I need to remove a couple ic's on a tv board to replace. It seems like it takes quite a long time to heat up the area on a scrap board. Should I go with something a little more powerful like the 858d? I wont be doing a lot of this work but some. Thanks Michael
Offline wraper
  • Country: lv
Re: New tool or not
« Reply #1 on: January 14, 2019, 09:18:18 pm »
140W / 6L/min is very weak for hot air. Good general purpose hot air stations like Quick 861DW have 1kW heater.
It's 5 times more powerful.
Also it's good to have a preheater which you place under the board.
Re: New tool or not
« Reply #2 on: January 14, 2019, 09:24:30 pm »
Trying to stay pretty budget friendly...will any of the cheaper ebay ones work for this part timer?
Offline wraper
  • Country: lv
Re: New tool or not
« Reply #3 on: January 14, 2019, 09:45:37 pm »
Offline KL27x
Re: New tool or not
« Reply #4 on: January 14, 2019, 10:50:30 pm »
Rating on the 858D says 700W. I can't say I've ever done anything particularly challenging with it, but it has never let me down and I have never had to screw with the temp setting or airflow to try to get it to chooch mo better.
The 858D has a very small footprint. It has the heater in the handpiece, so the cord is very light and flexible. So if it does meet your needs, you have a nice compact and reliable unit. I have a big diaphragm pump hot air unit, and it's been in storage since I got the 858D. If it doesn't work, you are only out $30.00 and you can buy a larger bulkier and more expensive unit with more more output. I can't imagine the Quik does too much more, though. A hot air gun has higher output, too, 1200W vs Quik 1000W. But at some point you need a preheater. You can't input that much heat onto a <5 square inch area on the top of the board, only, because you'll burn the board. My experience with a 1200W heatgun is that this is way more power than useable in any conventional way, even without a reducer. So more not necessarily better, unless you wanted to rig your hot air machine to be a preheater with a big ole diffuser on it. The main difference is that a higher rated heat gun might warm up a little faster from cold off the cradle. From a cold start, I wait about 5-10 seconds before using the 858D. It takes longer than that for the display to hit the set temp, but the parts (that I do) will reflow before that, anyway.
« Last Edit: January 14, 2019, 11:19:53 pm by KL27x »
Re: New tool or not
« Reply #5 on: January 15, 2019, 09:07:12 pm »
Thanks for the advice, I think for now I will just gamble with the 858D for $37 shipped. Maybe after I recover from the microscope purchase I can upgrade. Michael
Offline bson
Re: New tool or not
« Reply #6 on: January 16, 2019, 12:39:18 pm »
Consider a hot plate for larger boards and IC packages (esp BGA, QFP past 100 pins).  I have this: https://www.amazon.com/Aroma-Housewares-AHP-303-CHP-303-Single/dp/B0007QCRNU ... It seems people also buy it for cooking and heating food. :-DD
