You've just reminded me...
I bought a cheap DVD player, and upon plugging in the RCA cable (touching the ground the rca cable) when I came into contact with the back of the DVD player case, I got a nice tingle....
Measured 200+ volts from the dvd player case, to mains earth...
Pulled it apart, and found that instead of connecting the capacitors across the mains, they'd connected them from active, to the case....
(If it was plugged into something else that was earthed, it wasn't an issue)
Took it back:
"Hey, this dvd player has a design fault, the case is at mains voltage, they probably shouldn't be sold anymore till its fixed"
"ahhh, so... do you want a refund?"
