Careful with those Toshiba modules, I used one to control a 60W BELL linear lamp as an alarm wake up in winter, and the module failed after about a year of operation, flickering on intermittently then going short circuit. Seems the inrush current of the linear tungsten lamp was too much for the module.
Replaced with an OPTO22 module, a little overkill to use a 20A SSR with zero cross switching to control a 60W lamp, later replaced with a 32 candlepower carbon filament lamp as a more appropriate light source. Just pulled out 3 at work this week, been hiding under a shelf unused for around 3 decades.
