Author Topic: Filtering boost converter noise?  (Read 1374 times)
Offline ok_coolTopic starter
« on: October 20, 2015, 08:00:10 pm »
How should I filter out noise coming from 1.6MHz boost converter? Presumably some noise must come out of that IC?
Can I use RC and LC filter or is there some good way to deal with the issue?
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Filtering boost converter noise?
« Reply #1 on: October 20, 2015, 08:02:57 pm »
Are you talking the output itself ? yes LC filters. often in datasheets a secondry output LC filter is specified as optional, in theory you can have as many as you like, of course eventually the resistive part of the inductors will cause voltage drops
« Reply #2 on: October 20, 2015, 08:10:02 pm »
How much noise?
Which device?
Most manufacturers datasheets have specific guidelines of layout and component selection to optimise performance.
Are you following these closely?
Avid Rabid Hobbyist.   Come visit us at EMEX Stand #1001 https://www.emex.co.nz/
