thanks for the replies guys,
tpowel, yes i know about all the training, i am constantly watching youtube and have been for the last 4-5 months (that is how i ended up here, with daves blog), several videos a day, and know a lot more than i did a few months ago, however some things still occasionally confuse me, i assumed that the circuit could run both ways. however, what i also see with that circuit is that the (say 100v) power from the cap can flow straight to the LED's causing them to blow.
now, some of the things that i would ask is..
1. does the .5 watt resistor after the LED's only allow .5 watt through it at any one time? (ie, no matter the watt into it. it will only allow .5 watt through?) this has never been clarified for me. ie is that the maximum it will pass. (from the videos, all you are told points to a .5 watt resistor should be used in a .5 watt circuit etc.. )
All training videos are not detailed enough they don't tell you what you need to know. i know what a resistor is meant to do, i know how to work out the values needed, but no where does it say, you can use a .5 watt resistor in a 20 watt circuit and it will only allow .5 watt through. for that reason i assumed, that i would need to use a 20 watt resistor for that 20 watt circuit)
its hard to find some stuff on the net.. For example. it took me a few months to find out that electricity in a circuit will go via the easiest route possible.
now another question, the diodes, i know they have a overflow feature (cant remember the name
), ie the diode is say 5v, anything above that is let through, however im sure they have a cap too.. if it goes above that it completely decimated the diode, so would the 100v. not destroy them too.
based on question one.. the easiest way to say it is.. if i took power from the wall, and connected it to a .5w resistor, and sent it back.. would the resistor and LEDS not be destroyed. ? in other words, would a large cap not potentialy destroy this circuit ?
as i said before, i coudl just put the big resistor to two wires and use them directly to discharge the cap, however, i just wanted some sort of warning for safety reasons.
cheers
hope my questions are worded correctly
