Author Topic: Newbie question about Oscillators (not crystals!) and Load Capacitance  (Read 2468 times)
Offline PsychedelicBreakfastTopic starter
I'm looking to purchase a 8MHz oscillator for a project, and I've settled on this http://www.txccrystal.com/images/pdf/7c-tight.pdf. Most of this is straightforward, but I'm confused about the term "Load Capacitance" - doesn't apply to crystals? When using a crystal with a uC, one has to use capacitors of 22pf or so to make it work. Do I need such capacitors to use with oscillators too?
I intend to use this with Altera CPLDs. The development also has a 10Mhz oscillator onboard and when I look at the schematic, I did not see "load capacitors" so I'm kinda confused on how to proceed. Would appreciate some help.
Offline jahonen
Re: Newbie question about Oscillators (not crystals!) and Load Capacitance
« Reply #1 on: December 02, 2011, 10:00:32 am »
You don't need any extra load capacitance. Load capacitance is critical only with crystals to tune the oscillator at right frequency. Put one series resistor (something like 22-47 ohms or so) right at the oscillator output to provide some series termination.
Regards,
Janne
Online wkb
« Reply #2 on: December 02, 2011, 10:00:39 am »
This is most likely the maximum capacitive load the oscillator can drive at a given supply voltage.
Why they mention multiple capacitances per supply voltage ??
Wilko
alm
  • Guest
« Reply #3 on: December 02, 2011, 09:36:10 pm »
The same question came up earlier:
Oscillator load capacitance.
Still no answer what the multiple capacitance numbers per voltage mean.
