Author Topic: Fluctuating AC/DC readings on my new digital meter  (Read 19911 times)
Offline gioliciousTopic starter
    • tinkerBOY
« on: December 02, 2011, 10:20:43 am »
I got a new digital multimeter today and wanted to test some AA batteries and our mains. But before i would even test anything, i already see fluctuating readings on my meter when i turn to AC or DC. Is this normal? although i get accurate readings when testing. i've got an auto range digital multimeter.
Offline mobbarley
Re: Fluctuating AC/DC readings on my new digital meter
« Reply #1 on: December 02, 2011, 10:22:38 am »
You mean that the display is changing without anything connected? How much does it vary by?
Offline grenert
« Reply #2 on: December 02, 2011, 11:06:19 am »
This is a recurring question here.  You need to short the leads together to get a zero reading on your meter.  You will get nonsense readings like yours on a DMM if you are on ACV or DCV with nothing connected, or the leads connected and not shorted together.  It is a consequence of the high input impedance of DMMs, which is generally a good thing.
    • tinkerBOY
« Reply #3 on: December 02, 2011, 11:12:50 am »
Yes that's what i meant.
Please see attached pictures.
I tried shorting the leads and it went down to zero but otherwise it's displaying fluctuating readings still. So I assume this is normal? Please see attached pictures.
« Last Edit: December 02, 2011, 11:15:02 am by giolicious »
Offline mobbarley
« Reply #4 on: December 02, 2011, 01:01:43 pm »
As above - nothing to be concerned about, that reading is very small. Assuming that it drops to practically zero when the leads are shorted.
    • tinkerBOY
« Reply #5 on: December 02, 2011, 01:59:29 pm »
yes it drops to zero when shorted. ok thank you guys.
alm
  • Guest
« Reply #6 on: December 02, 2011, 09:46:32 pm »
One of your pictures shows a 50 mV reading. With a 10 Mohm input impedance, it takes about 5 nA to induce this voltage. This can easily be picked up by the leads. This problem is worse on some meters with an even higher input impedance. Even some cheap DMMs have a FET-input (Gohm impedance or so) mode on the lowest mV ranges.
This can actually be a real issue, and is the reason why some of the products aimed at electricians have a lower input impedance, or the ability to switch from 10 Mohm to a few kohm or so. If you're measuring the voltage between two wires, you may not have any way to check if they're connected. Capacitive coupling with other wires can easily give high (eg. 80V) voltage readings with 10 Mohm DMMs.
