Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Newbie - Switching base on bias
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Newbie - Switching base on bias (Read 3150 times)
yosmanor
Newbie
Country:
on:
June 21, 2016, 11:28:16 am »
I need a switch that will turn on a 5V circuit when the input is zero while the circuit will remain off while the input is 5V.
I have minimal education in electronics. Any suggestion is welcome.
I experimented on the attached circuit without success (naturally).
Logged
bitshift
Regular Contributor
Country:
Too much to learn, too little time
Re: Newbie - Switching base on bias
Reply #1 on:
June 21, 2016, 12:25:44 pm »
You need to use a PNP transistor like this:
R2 is there to tie the base of the transistor high (off) when the base is floating.
Last Edit: June 21, 2016, 12:43:03 pm by bitshift
Logged
"It’s all fun and games until an innocent opamp gets hurt!" - Dave Jones
yosmanor
Newbie
Country:
Reply #2 on:
June 21, 2016, 12:50:09 pm »
Thanks
Logged
rstofer
Super Contributor
Country:
Reply #3 on:
June 21, 2016, 01:02:45 pm »
It would be interesting to know how much current is being switched. If it's tens of milliamps, no problem. If it's tens of amps, that poor 2N3906 will go up in smoke.
Logged
bitshift
Regular Contributor
Country:
Reply #4 on:
June 21, 2016, 01:04:57 pm »
Absolutely. The 2N3906 is just what was in the first image a quick google search found. Replace with a suitable transistor.
Logged
yosmanor
Newbie
Country:
Reply #5 on:
June 21, 2016, 01:16:02 pm »
Thanks guys,
The current will be 2A or less.
Logged
Helen95
Newbie
Country:
So much to do and so little time
Reply #6 on:
June 23, 2016, 12:36:49 pm »
Forgive me please for butting in but where is the difference. Or rather when should I switch from 2N3906 to something more powerful?
Logged
bitshift
Regular Contributor
Country:
Reply #7 on:
June 23, 2016, 02:02:32 pm »
Each transistor will have a maximum collector current which will be listed as "Ic" in the transistors datasheet. The most basic reason to get a "larger" transistor would be when the amount of current you need to pass through the transistor approaches the maximum specified in the datasheet.
Logged
StillTrying
Super Contributor
Country:
Country: Broken Britain
Reply #8 on:
June 26, 2016, 12:05:53 am »
2N3906 is 200mA Max. and that will only be if it's properly turned on/saturated, - so well below 2A.
A 3A is probably needed, and the correct base current calculated.
Random silly question: Are yosmanor and Helen95 both the same person.
Logged
That took
much
longer than I thought it would.
yosmanor
Newbie
Country:
Reply #9 on:
June 26, 2016, 01:52:36 pm »
yosmanor and Helen95 are not the same person
Logged
Audioguru
Super Contributor
Country:
Reply #10 on:
June 26, 2016, 03:38:50 pm »
In the first post the load is an LED that will go up in smoke if a current-limiting resistor is missing.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
